Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
P1 error - Will not rinse. - Hobart 24 in. LXIH-3 Built-in Dishwasher
    Scholar:
    New Friend:
  • 135 Answers
Found this from another solution about the P1 error. Might be helpful:
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
kc
Posted on Mar 18, 2011
  • workingranch Mar 18, 2011
    Where can I find the part?
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
Hobart am-15 ml-130038 displaying p1 error
I replaced the probe temp according to error code P1 but the display still shows error P1. Is there any suggestion for further troubleshooting?
Nov 08, 2011 | Hobart 29 in. AM15-1 Free-Standing...
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
356 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
