Question about Dishwashers
How do I reset programme for teka dishwasher - Dishwashers
  • yadayada
    yadayada Mar 18, 2011
    There is no reset, it either works or it doesn't
4 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: Teka Dishwasher DW6 59 FI
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
  • 3247 Answers
SOURCE: Teka DW6 59 F1 Lights 4&5
I am slightly unclear if lights 4 & 5 are counted left to right or right to left when facing the dishwasher.
If you are counting right to left - then lights 4 & 5 flashing implies E3 fault - heater failing to heat.
am suspecting the heater unit is failing. Try to run dishwasher on a colder program like DELICATE and see if goes through.
If the flashing does not go away by turning power off and back on then the heater or the thermostat has failed and will need replacement.
Hope this helps fix the problem. Please post a comment if this is not helpful.
Posted on Mar 17, 2011
SOURCE: how to reset a dishwasher teka lp700
i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
Posted on Aug 25, 2011
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Hi my teka dishwasher dw7 56 fi makes a noise when first switched on .
what is it supposed to do . be so quiet you can not hear it working .
Dec 07, 2015 | Dishwashers
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
How do I fix a Teka DW6-59 dishwasher thermostat problem
If it heats and fills, would not think thermostat, tstat checks that the temp is ok, then prog moves on, If tstat, would never move on. think more after that, maybe, does the pump work, could be broken wire power to pump, can you hear the pump working, if continuois cycle, at what point does it stop and start at beginning, does it pump water out? if not water level sensor.
Jul 29, 2014 | Dishwashers
All five lights are flashing on teka dishwasher
The control board could be at fault
Mar 26, 2013 | Dishwashers
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Need an english manual for teka dishwasher dw6 59 f1 please
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
How to reset a dishwasher teka lp700
Apr 19, 2010 | Dishwashers
How to reset the programmer on dishwasher
Disconnect power for longer than 45 seconds.
Sep 17, 2009 | Dishwashers
Dishwashers Logo
346 people viewed this question
Top Dishwashers Experts
Owen Barnes
