Question about Guest 2111a Universal Mount Marine Battery Selector Switch (230 Continuous 345 Momentary Amps Black)
I have an electric friction motor on trike, For more distance I am adding a second battery (12v 18ah) in parallel. Need to put switch in line so one battery runs at a time. Then I know it is time to go back home and will use second battery. What gauge wiring do I need? Can I turn off the second battery when home and charge each one separately? I have two 2amp chargers. Thanks for your time, Chrome
  • 693 Answers
Hi Chrome
I'd use pre-made automotive battery cables as they'll easily handle the amperage output as well as already having the ends factory installed.
With your battery selector switch, you'll be able to charge one batt at a time.
You'll need a ground from one battery to the switch and a common ground cable connecting the ground of batt 1 to the ground of batt 2 to make this work. Each HOT lead from the batts goes to the switch.
Hope this helps.
Posted on Mar 18, 2011
  • roamwchrome Mar 19, 2011
    Thanks for reply. The batteries are motorcycle. Won't the ready made cables be to long? The batteries will be back to back becaise of space problems. They won't be the heavy car cable. I thought it would be easir and cheaper to make them. Besides they will have to be cut to put the switch on. Thanks
  • Steve
    Steve Mar 19, 2011
    Thanks for clarifying your battery type.
    I'd estimate that your current draw would be in the order of 30 amps or so, o a primary cable of 10 ga should suffice. (10 gauge will work up to 55 amps.)
    A good website for wire specificatrions is at: http://www.powerstream.com/Wire_Size.htm
    Good Luck!
I have inherited a Rascal Fold and Go 370 and have ordered two new replacement batteries to go in the battery case......however, my husband does not remember how the batteries are wired back in the ca
the batteries are wired in series, meaning two 6volt packs are wired nose to tail so they can deliver a full charge, OR they are wired so that both are in parallel, and each pack contains 1 Ampere-Hour of energy at 12 VOLTS and you use 2 packs to get 2 Ampere-Hours of "CHARGE". What your significant other has to get before he connects the wires back up , is a VOLTage METER to verify the polarity of the wires coming from the adaptor. It USUALLY is RED for positive, BLACK for negative........ but not always....... measure to be sure, then double check.
IF it is two 6 volt cells that are connected in Series, then the red of the first pack goes to the RED WIRE of the adaptor, then the BLACK WIRE of the first cell goes to the RED WIRE of the second cell and the BLACK WIRE of the second goes to the BLACK WIRE of the adaptor.
*Your mileage may vary, not intended to give professional advice, all actions are at your risk, Federal Deposit Insurance will only cover cash deposits at Federal Registered Banks. Colours may fade over time. Always call a friend when you need the answer.
Nov 24, 2014 | UPG 12V 18AH Rascal 110, 120, 370 Fold &...
How do i connect 4 batteries in series
Here is the way to hook them up in series, or in parallel.
There are 3 batteries in top (series) pic, but a 4th would be added in same wiring manner. Disregard the letters "ve" in diagrams, but the +/- polarity is vitally important in hookup.
Note that four 12v batteries hooked up in series will be 48 volts at the end terminals. (If all four are hooked up in "parallel" then the total would still be 12 volts).
If you want to supply a 12v inverter, you need to hook 12v batteries in PARALLEL.
Nov 01, 2014 | Cobra 2500w Power Inverter
Were can you et a new battery peak portable power system 450
Open it up and find out what kind of batteries are in it.
12V 18Ah Sealed Lead Acid AGM (Absorbed Glass Mat)
AKA Gel Cell
Dimensions not listed.
Don't be surprised if the replacements cost more than the device.
The user manual says that the unit is not designed to have the battery replaced.
http://allpowersupply.com/Productlib/manual-PKC0BK.pdf
12V 18Ah Sealed Lead Acid AGM Google Search
Oct 20, 2014 | Vehicle Parts & Accessories
How do you charge the EV warrior?
You need to obtain an "EV Warrior SuperCharger". I just found a few on Ebay for about $80
It is a 5A-24v battery charger with a standard 3 Prong Connector
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
I have a dual marine battery charger on my boat that is wired thru a 1-2 or both switch both batteries are 12 v batteries and i was wanting to know if i could add another two 12v batteries to the sy
It sounds to me like you have an Ad-A-Battery system or something similar. Your dual battery charger has two sets of output leads. Those leads should be connected DIRECTLY as one set of leads to battery #1 and one set of leads to battery #2. Your 1-2-both switch should be OFF when you are charging. You will, I suspect, be supplying current to your motor and other boat circuits by having the switch on and running your charger through that switch. Adding two more batteries could be accomplished by buying a four battery charger (four sets of output leads) or buying a second dual battery charger. When you only want one AC plug-in you connect both charger AC inputs to a small junction box that is fed current by the AC plug-in. That will be nice and simple and safe. Of course, you need to check wire size to make sure you have proper size for the length of your wire runs.
Mar 10, 2013 | Marinco Guest 2620 Waterproof Charger
Ebike in need more power adding
You can add two 12 V 12AH battery in series. The total power now would be 720 W and your motor can bear it.
Oct 19, 2012 | Prodeco Technologies 2012 Stride R 36v...
Ebike in need of more power by adding batteries..
A 250W electric motor will only pull about 5.1 amps at 48V. The lead acid batteries that come with the bike are more than capable of 5A of output without dropping voltage. Therefore, wiring a second pack in parallel will not do anything to increase the available torque or power from the motor. All it will do is increase the time/distance you can ride the bike on a single charge.
Also, you should take care that wiring lead acid batteries in parallel is not always safe, especially if you are wiring newer batteries in parallel with older batteries. A common failure mode is for one of the cells (there are several in each battery) to short circuit. For a series-wired pack, this only decreases the voltage, but if you have two packs in parallel, you'll end up with one pack having a lower voltage than the other, and it will draw tremendous current out of the other pack, possibly causing an explosion and great bodily harm.
If the performance changed suddenly after hitting a bump, then you probably broke something in the hub. If the motor has multiple windings, it's possible one of them became disconnected from the power source. This would decrease the available torque and power. I would look into having it repaired.
Be careful, and ride safely.
Nov 07, 2009 | Electric Bicycle Motor, Bike,electric...
Guest 2111a Universal Mount Marine Battery Selector Switch (230 Continuous 345 Momentary Amps Black) Logo
234 people viewed this question
Top Guest Boating Experts
appman67
appman67
Steve
Steve
ray gallant
Are you a Guest Boating Expert? Answer questions, earn points and help others
