Question about Weller TC201T: Soldering Iron For Wtcpt, 42 Watt
I bought a Weller TC202 power unit with a TC201 soldering iron. The iron does not heat. Instructions from weller said to check the resistance across the heater and it should be about 13 Ohms. It reads 0. The replacement heater tc208 shows two wires to be connected, my heater is a 3 prong plug in. Did I check the heater correctly? Any suggestions
Dissolu
  • 221 Answers
SOURCE: repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Posted on Jul 24, 2009
Vanguardian
  • 106 Answers
SOURCE: Weller WMRP soldering iron faling prematurely.
I suggest that you set the "Auto Time Off" much longer or turn it off by setting it to 0, and use a standby of 400 degrees after 10 minutes instead.
The reason is that every time this soldering iron has to turn on, it's trying to heat up in about 5-10 seconds. When it does that, it applies full wattage to the heating element, and putting full wattage on them a lot of times is what's burning them out. If the soldering iron maintains the same temperature while not soldering, it only uses 20-30% of the full wattage to keep it at the set temp. This isn't nearly as hard on the heating element.
Posted on Sep 11, 2009
  • 5603 Answers
SOURCE: Before ordering a replacement cord (TC217) for a
Wiring is easy... look at the parts blowup here. It appears that two of the wires from the cord use wire nuts to attache to the elelment and switch.
http://www.action-electronics.com/pdf/wtcpt.pdf
Posted on Jan 19, 2010
nitrospawn
  • 290 Answers
SOURCE: I have a faulty weller soldering iron.
It may be possible that the voltage
input is low it will affect the
temperature.if not change the
thermostat
Posted on Apr 11, 2010
  • 33 Answers
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Posted on Aug 30, 2010
I have an old Weller soldering iron model 8250a that I would like to repair. It has burnt up wiring, and I'd like to find a wiring circuit diagram, schematic or ANY kind of electrical drawing, comple
These were very simple and sturdy soldering guns [I still have 5 or 6 of them in various sizes] They basically have a transformer wired so that the heating part is basically a short circuit of the large low voltage secondary winding [very low voltage] and because the tip is higher resistance than the rest of the heat producing end, it gets hotter sooner. The secondary is just a single loop of the tube that holds the tip. Usually the only maintenance is to loosen and re-tighten the tip mounting nuts so that there is a good electrical connection [no connection = no heat; poor connection = poor heat]
There may be another small secondary winding that provides power to the light but I think the older ones just attached the lighting wires to the large secondary.
The primary [line voltage] winding of the transformer is switched such that the higher wattage powers the lesser resistance part of the winding and the lower wattage powers the higher resistance part of the same winding. In other words there is a single wire for the primary that has a tap near one end of the winding for dual heat.
If the two windings to the switch are mixed up the higher heat will just be at a different trigger position; if you don't like it, switch them around.
Also check the connection to the non-switched wire from the cord for a good connection. The switches are still available, at least for the newer models; do a google search for
Weller soldering gun switch
or
Weller 7324
Untitled Document [for a switch supplier]
Weller Switch Dual Heat Gun 1 Each 7324
Feb 10, 2015 | Weller Welding Tools
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
The tip of my weller 200D soldering iron was replaced about a month ago. I have just plugged it in to use it and it is not getting hot anymore.
This happens quite frequently. On the tip there are two nuts that hold the tip to the gun. Tighten them a bit. The tip is made of copper and as this heats, it causes the connection where the nuts are to become a higher resistance and thus lower heat. When you tighten them, it "cuts" through the copper oxidation (caused by the heat) and lowers the resistance, hence more heat.
Jan 11, 2011 | Weller Welding Tools
Jul 11, 2010 | Weller Welding Tools
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Before ordering a replacement cord (TC217) for a Weller TC201 handset, I would like to know how the cord is installed on the handset end.
Sep 27, 2009 | Weller TC201T: Soldering Iron For Wtcpt,...
Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
Mar 24, 2009 | Weller D550PK Professional Soldering Gun...
Weller TC201T:  Soldering Iron For Wtcpt, 42 Watt Logo
1,814 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
