Question about 477L Ask RXTX HHU Remote
My remote starter is cranking the car but as soon as it cranks the remote starter is shutting right off. It does this every time I try to use it.even when I start the car by hand and then try to activate the remote starter while the engine is running it still just shuts right off.can you help me with this problem thanks
    Sergeant:
  • 247 Answers
Hi This is an earth problem you need to ensure your starter is earthed properly or renew the earth cable is best this should solve the problem. Please leave me feed back: Malcolm Campbell, Thanks.
Posted on Dec 03, 2017
5 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 34 Answers
SOURCE: Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Posted on Jan 09, 2009
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
SOURCE: Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
replaced battery in 2002 s10 now bulldog remote starts and shuts off also have 791 module instaled
Posted on Feb 28, 2010
lnlkustomz20
SOURCE: Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
I just went thru this, unplug everything from the brain on the remote starter, then plug it back in and reprogram the bypass and you should be good to go.
Posted on Nov 20, 2012
96 dodge caravan 3.3 started then died and now will not start or even crank lights work dash lights up but nothing from under the hood new ecm starter battery and crank sensor have all been put on what...
If you replaced the ECM and didn't reprogram it. There's your problem. The ECM doesn't recognize the security code. And it will start and kill the vehicle three times before shutting down everything. IE.. starter, fuel.
Mar 28, 2015 | 1996 Dodge Caravan
My starter went out in my 2000 Oldsmobile Silhouette. I replace it with a brand new starter, without key in ignition the starter was winding as soon as I reconnected the battery. However, while doing...
You hooked it up wrong . Is there power at the purple wire all the time ?
ignition the starter was (winding ) ???as soon as I reconnected the battery. The starter cranks the engine !It's really called a cranking motor not starter . Do you know where that comes from ? Before electric starters you cranked the engine by hand . Suggest you take it to a qualified repair shop.
Jun 10, 2017 | 2000 Oldsmobile Silhouette
When I put the key in the ignition it doesn't try to start everything else comes on then shuts off. I drove it yesterday but now it won't work
The remote starter module is not getting an electrical signal when you turn the key to the on position after remote stating the vehicle. When you depress the brake without turning the key on the vehicle shuts down. The remote module thinks the key is off even when you turn it on. There is a loose connection or the remote start device is defective.
Jun 04, 2014 | 2005 Chrysler 300
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Jan 28, 2014 | 5301 LE 2 Way Car Remote Starter System
Hi can any1 help me with my nissan sentra problem?my car just shut off while driving and lost power be for it shut completely off tried to crank it back up but it didn't start sprayed some starter
Crank shaft sensors often fail without triggering a code. But in its early stages, a check engine light may be on. Symtoms of a bad crank sensor are: poor acceleration ( lack of power ) rough idle, ETC. sometimes you may be able to start it normally, and other times it takes 3 or more times. If the check engine light is on take it to a auto parts store and thy can read the code for free. To tell if that's the problem. God-Bless!
Apr 18, 2013 | 2004 Nissan Sentra 1.8
I have a 94 s10 blazer 2wd 4.3 vortec vin w. when the engine is hot (normal operating condition) the starter will drag a couple of times and then it will crank over a bunch before firing off. sometimes it...
Check all the battery and starter cables,particularly the earth cables off the battery.Also check the battery clamps.Check the earthing between the engine and chassis.if this is bad you can get this type of problem.
Jun 19, 2011 | 1994 Chevrolet S-10 Blazer
2006 Pontiac Montana wont start after replacing battery. Engine cranks as soon a key is moved from off, then continue to crank even after removing the key.
Sounds like your starter solenoid is stuck in the on position if you can get down there and have some one hook the battery on, hit the starter with a hammer some time this will disengage the starter.
Dec 13, 2009 | 2006 Pontiac Montana SV6
1987 ford rangers starter will not quit cranking
sounds like your contacts in your starter have froze shut it is time to replace the starter
May 17, 2009 | 1987 Ford Ranger
Car will not crank over
there are no sensors on any car that would keep the starter from engaging even if the fuel tank was completely removed remove the starter and have your local oreillys or autozone bench test it if its good then you have an electrical issue could be related to your ignition switch, starter and or ignition relay or fuses check all of those
Apr 07, 2017 | 2003 Chevrolet Avalanche
Starter clicks 1 to 20 times before it cranks and ocassionaly when running it grinds starter even when you turn key off it continues to crank for 10 to 20 seconds batery replaced and good terminals
Either your starter is bad ( which it sounds like it soon will be) or the starting solenoid in the system is faulty ( which it most likely is right now). If that doesn't work, have a diagnostic run and repost with any new info.
Aug 07, 2008 | 1992 Toyota Corolla
477L Ask RXTX HHU Remote Logo
60 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
