Question about Dryers
No heat Is the drum turning? yes Is heat selected? yes
  • 1,531 Answers
You will need to check the thermal fuses they are located next to the heating element.If you have a volt meter you will need to check the continuity on all the thermal fuses and the heating element replace the part that has no continuity.
There are times that the main circuit breaker can be bad you may need to check the power and make sure there is 220 volts to the unit.As you check the thermal fuses and heating element make sure the unit is unplugged
Posted on Mar 19, 2011
The dryer starts to heat, but the drum does not turn
When you start the dryer do you hear the motor running if so the belt from the motor to the drum of the dryer is broken has to be replaced.
Jan 29, 2015 | Dryers
Lg DLE2240w
it is hot inside and the drum turn? yes: look for lind in your outlet pipe. no: the heat element or the thermal fuse is out. if the drum dont turn, change the strap. (is all this are ok, look the fan impeller) tank you
Mar 29, 2014 | LG DLE2240W Dryer
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Workio DP-190 all in one Fax Machine. We have recently replaced the toner drum in the last couple of months. But are now recevining a error message saying to replace drum unit. Is there a way to...
yes there is a user troubleshooting to reset the drum counter.
you may follow these steps:
  1. press FUNCTION key
  2. press 1 to select general setting, then press SET to select
  3. press scroll V or /\ to locate the "replace drum" setting
  4. it think it will as for confirmation, if so just press 1 for yes, or 2 for no.
  5. press stop key to exit
  6. you might turn off/on your machine if needed.
that's it. :)
Feb 18, 2010 | Panasonic Workio DP-190 Multifunction...
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
Have a whirlpool gb awz2303 heats ok but drum would'nt turn turned drum around went ok for about a month then same thing happend do you think its the belt streched
By what your saying, yes the drum belt is stretched and or is sliding out of track. You can check this by removing the back panel, be sure to shut or unplug power first, then you will be able to see what i am talking about. hope this helps
Oct 07, 2009 | Whirlpool GEW9878LW Electric Dryer
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Whirpool lgr6620pto will not heat up and will run all day untill i open the door
Heating element is either burnt in two or vent pipe is clogged with lint or birds have made a nest in the pipe on the outside wall or roof. Yes, a bird can lift that little flapper door up and will fill that pipe until it is clogged. To check to see if it is a heating element, close the door to your laundry room & the light out, turn the timer knob to any selection, with the door open & no clothes in the drum, find the door switch located somewhere around the door frame and hold it in while turning the start knob on. If the element is good you will see a red glow coming from the vent holes at the inside back of the drum. No glow, no good.
Jul 09, 2009 | Dryers
Brother MFC-7820N Drum Reset
There is no clear buttom as mention abovee.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Nov 03, 2008 | Office Equipment & Supplies
Panasonic PanaFax UF-490 Problem with Drum Unit
for manual setting.. when replacing the drum unit.. press function 7 thend scroll down select maintenance then scroll donw select drum unit then press 2 to clear the usage.then press 1 for yes.
jamming or misfed?
try to check the drum unit you install.see if the drum not installed properly. turn off and on the unit
Aug 02, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Dryers Logo
26 people viewed this question
Top Dryers Experts
