Question about Epson Office Equipment & Supplies
Is it worth fixing Hi we dropped an epson projector from 8 feet. It has power and does project a clear image. The image is more like 3D now and the plastic is cracked.The school has more projectors. Can it be fixed? Jim A Dist.111 Minooka High School
  • 442 Answers
You have several choices,
[1] issue students with 3D glasses, and explain that the unit has been upgraded to 3D
[2] Is the 3D effect for one colour only or all three primary colours?
[3] pull it apart and check if the optical components are all intact.
chances are that a mirror is misaligned and a simple adjustment may fix it.
[4] tell us what model number it is
[5] failing all that, keep it as a spare for when the other units die and need costly parts for their repair.
Posted on Mar 18, 2011
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Epson projector center blurry
Sounds dumb on this one but make sure the lens is cleaned. Other then that check the manual for operating range of lens to screen. Typically somewhere in the area of 8 to 12 feet.
Oct 09, 2012 | Epson PowerLite 83 Plus Projector
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Dell 2200MP Multimedia Projector
Hi PFCS
Check out my answer to your other posting.
I would suggest you to at least get a quote first and then decide on what to do - chuck away - or - repair -
May 20, 2008 | Dell 2200MP Multimedia Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
May 03, 2007 | Dell 1100MP DLP Projector Multimedia...
269 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
