Question about Fender Frontman 65R 65W 1x12 Guitar Combo Amplifier
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the clean channel have almost no effect on the sound. Is that also normal?
  • 1,606 Answers
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Posted on Sep 11, 2011
  • Anthony
    Anthony Jun 04, 2017
    I have same issue with my amp. Just verifying about the pot number. I look up the schematic and it showing the pot for reverb is R57. Can you please verify?
    And what is the function of U4?
I have a fender frontman 65r with a 8ohm speaker can i add another 8ohm speaker to this
http://cie-wc.edu/Series_Parallel_9_14.pdf
Not recommended.
you could add 3 more 8 ohm speakers in series / parallel wiring and keep an 8 ohm load to the amp, or
2x 4 ohm speakers in series, or
2x 16 ohm speakers in parallel
Jan 11, 2014 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Nov 01, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My fender frontman 65r started crackling even with nothing plugged in
This sounds like one of this nasty problems with the solder points. One of them might be faulty so sometimes there is a contact sometimes not. You could try to locate it by knocking gently with the plastic end of a screwdriver on the pcb. If vibrations cause the noise you could check all solder points optical or just resolder them. There are not too many. Also check all potentiometers! As they are mechanical parts vibration caused issues can be found here very often especially on their solder points.
Mar 15, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hi, I bought a Frontman 65R a couple of years from now, but last month I've moved to South America and I forgot to buy a Voltage transformer to use with the amp. (It changes from 110 volt to 220...
the fuse hopefully took the brunt of the higher voltage,, replacing the fuse should do the trick, but yes you need the voltage transformer for sure they sell them pretty cheap here, Just be sure and look for the wattage in each one http://www.dvdoverseas.com/store/index.html?loadfile=catalog6_0.html
Jun 02, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Need reverb tank for a Marshall Amp 8280,but don't know what type
Try this website:http://tubesandmore.com/ Look under reverb tanks. Check to see how many springs your old tank has and what size it is. I think Marshall used Accutronic tanks but have a look at all of them. There are pictures and info for each. Hope this helps.
Feb 27, 2010 | Music
Reverb wont work !!!!!!! Hot rod deville 410
probably a bad reverb tank. there is a little inductor inside that shorts out easily/common. you cant repair it. its just easier to order a new tank. what you do to test is........turn on the amp with the reverb turned up all the way........ volume up on the amp at normal playing level.....then tap or knock on the reverb tank itself......if you get sound then the output of the tank is good/ no sound the ouput side is dead.......then what you do is unplug the ouput of the tank and plug the output wire to the input of the tank and tap/knock on it again....if you get sound then the input side of the tank is good/ no sound is dead. this is a way to test the tank independently from input to output. which side is bad is irrelevant, what is improtant is determining if the tank is toast. i can get accutronics tanks from my distributor at a better price than anywhere else. email me thru my contact page on my website with the tank code numbers and letters so i can get you a price also check my price with whats on ebay, etc. my website is yostamplifier.com
good luck
Feb 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fender Frontman 65R 65W 1x12 Guitar Combo Amplifier Logo
242 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
