Question about Frigidaire Dryers
We have a frigidere gallery series gas dryer model #GLGQ942CSO Series # XD44608328 it keeps saying FO% on it
aborcass
  • 2651 Answers
SOURCE: dryer door clip
try replacing both the catch and strike , call local part wharehouse or order online, real easy to install just pop them in
131658800 - CATCH-DOOR
5303207102 - STRIKE
Posted on Mar 11, 2008
  • 10865 Answers
SOURCE: dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
Posted on May 27, 2009
  • 18 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
If gas is available after burner ignition for 3 - 10 seconds but then cuts out, this is an indication of a (1) lint clogged exhaust line,or (2) a fan suction bypass leak, both of which are resulting in insuffucient burner cone air/gas flow. Insufficient burner air flow results in actuating the high temperature limit thermostat or thermoswitch (usually a L220-40F thermostat) mounted on the topside of the cone. With inadequate cone air flow, burner flames are directed upward toward the thermostat instead of being pulled into the cone and then into the hot air supply for the dryer drum.
For (1), clear the exhaust line from the lint filter to the discharge louvers on the exterior of your home. Access to the backside of the dryer is necessary.
For (2), check the lint filter to fan suction connection for any possible leak paths. Access to the front interior of the dryer is necessary.
For a DG512, the front assembly that houses the lint filter and abuts the front end of the drum has a short duct that fits into the suction side of the casing for the squirrel-cage fan. This duct has a tendency to separate from the fan casing (its a slip fit) resulting in bypass leakage. If suction bypass leakage is occuring, this is air that is not being pulled through the drum, and hence, is not being pulled through the burner cone. As indicated above, a low cone air flow results in actuating the high limit thermostat, which then deenergizes the gas coils cutting of gas to the burner.
Note: These symptoms are NOT indicative of failed gas coils, since gas is being supplied initially to the burner for a period of 3 - 10 seconds. If the coil(s) have failed, the burner could not operate for any duration.
Posted on Oct 04, 2009
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
SOURCE: how do I install the shoe rack in my frigidaire
You have to remove the lint filter and the part of the shoe rack that sticks out then fits into the slot when the lint filter would sit.
Posted on Jun 28, 2010
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
I just bought a used gas dryer. It is a frigidaire gallery series model GLGQ2152ES, serial no. XD63710183. Can it be used with propane?
Yes but you will need to do some minor converting on the orifice and valves due to the difference in the gases. Your propane company will help you with that.
Jan 28, 2013 | Dryers
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Gallery series dryer shuts off.
Check your lint screen. If you do not get a complete "lint pattern" you probably have a clogged or partially clogged vent which will cause your dryer to overheat and prematurely shut off. Clean your vent and you'll return to normal operation. If you have a vertical vent (goes up through the roof) get a proffessional to clean it. Dryer vent issues are the #1 cause of house fires according to the U.S Department of Consumer Affairs. Over 16,000 per year.
Nov 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
61 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
