Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Have an Out of Service (3) on screen and the grounds drawer won't come out.
  • wdsinger Mar 21, 2011
    Problem solved. thank you.
  • Saeco Master
  • 19,396 Answers
Hi.
Error 3 are brew group errors. One of the following has occurred:
Maximum force exceeded in forward movement to dispense position
Maximum time exceeded to reach dispense position.
Maximum time exceeded to clear home position microswitch.
Home position microswitch activated while moving to work position.
The brew group is blocked in work position.
There is something stuck, and the machine must be disassembled and the brew group microswitch tested to fix the problem.
Here a service manual. It covers different Talea models including Ring Plus. Test mode for ring plus is illustrated at page 25.
Posted on Mar 18, 2011
Saeco odea eror
Alarm light:
• permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the grounds drawer is full.
• on and slowly flashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not inserted or the service door is open.
• on and quickly flashing : signals the need to prime the water circuit.
May 06, 2014 | Saeco ODEA Coffee Makers & Espresso...
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Dec 06, 2012 | Audio Players & Recorders
Screen won't display
It happens to most of the cell phones. The only way is to contact nearest cell phone service centre.
Jun 03, 2012 | LG VOYAGER VX10000 Cellular Phone
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Not working
Three possible causes.
1. The drawer where the coffee grounds end up is not properly inserted. To fix insert drawer completely.
2. The tab on the left side of the drawer is broken off. To fix purchase an new drawer.
3. The drawer microswitch has a problem. There could be many reasons for this. The machine will have to be opened up to see whats wrong.
Dec 02, 2008 | Saeco Royal Digital Plus Coffee...
Drawer will not go in
This just happened, I found that if you (1) remove the drawer, (2) turn off machine and wait a bit, say a minute or so  (3) turn it back on and finally replace the drawer WITHOUT the grounds bucket it will (may?) reset itself.  Don't forget to replace the grounds bucket afterwards.
As mentioned this is because the flap gets out of sync, I believe I caused this by having too much powder in the powder container.
Feb 13, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
284 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
