Question about Samsung HT-TZ512T Theater System with Wireless Speakers
Unit will not power up. everything is plugged in.
    Brigadier General:
  • 8,546 Answers
Is this a new unit that has never worked or a new problem on a previously working unit? It's important to know.
Try unplugging all the speakers and see if it turns on.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 18, 2011
Plugged into surge plug lost power it won't work. everything else does
Confirm that power is getting into unit. If so, then the power supply may be defective and needs work. Look for a reset button if any.
Jan 02, 2016 | Audio Players & Recorders
PROBLEM WITH ASUS DSL-N13 ROUTER, ALL 4 LAN PORTS ARE BLINKING FAST BUT HAVE NO LIGHT ON POWER, DSL.IP.USB, WIFI ALL LIGHTS ARE OFF. DID TRY TO RESET, DID UNPLUG THE POWER BUT NOTHING IS HELPING . IF YOU...
disconnect everything from the unit, then reconnect power.
If the unit behaves normally, start plugging things back in until it goes nuts again.
Whatever you plugged in last is the problem.
If the unit behaves the same, either your power adapter is failing (use a volt meter to check) or the router will need to be replaced.
Mar 15, 2011 | ASUS DSL-N13 Wireless Router
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
My APC BE500U keeps resetting
It certainly indictes a problem with the APC unit a replacement bettry may or may not solve the problem. Do you really need one as you have an anti surge protector?
Sep 18, 2009 | APC 500VA BE500U Back-UPS ES...
ACER power 1000 has no power at all
change the power supply, if still nothing then motherboard might be gone
Dec 31, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
***** turned on - won't power up at all
Fixed it by taking it back to Best Buy who replaced it within two hours of its original purchase. New unit works great.
Mar 09, 2008 | Nintendo Wii Console
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Samsung HT-TZ512T Theater System with Wireless Speakers Logo
73 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
