Question about Quartet gbc 2230S Shredder
Our GBC 3220S shredder's gears won't turn and it makes a loud noise when paper is inserted. However, when run in reverse the gears spin and there is no loud noise. What could be causing this?
4 Suggested Answers
  • 329 Answers
SOURCE: paper shredder
There is a housing arond the shredding wheels, they get jamed with paer and break the screws holding this guard around the wheels. Not sure on that model if it has those gray plastic guards, and they are available...
Posted on Jun 24, 2008
SOURCE: Shredder Replacement Gears
Am having similar problem looking for gears for 1036S
try www.compax.com/shredders/parts
or
www.factory-express.com
Posted on May 29, 2009
SOURCE: GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
Posted on Oct 22, 2011
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
Mar 28, 2011 | Gbc GLX2030 Shredder
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
My shredder won't take paper and makes a high whirring noise when in forward and reverse.
Sounds like the motor is spinning but not turning any gears or cutting shafts.... unplug, take the top cover off to see what is broken then give Royal a call at 1-800-524-0799 for parts.
Aug 01, 2010 | Royal 85MX Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
May 21, 2010 | Quartet gbc 2230S Shredder
Cannot get it shred forward or reverse. Is there a reset or fuse Paper shredder
probably has broken gears. Aurora does not produce replacement parts for any of their machines. Actually made by Royal and they don't make parts either so don't buy either brand.I guess Fellows is about the best brand or GBC.
Nov 13, 2009 | Memorex Paper Shredder
My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Aug 30, 2007 | Quartet gbc 6120S Shredder
GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
May 09, 2007 | Quartet gbc 3270M Shredder
Quartet gbc 2230S Shredder Logo
99 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
