Question about Whirlpool GH5184XPQ Microwave Oven
MY MICROWAVE IS A WHIRLPOOL GOLD MODEL# GT4175SPT-3 SENSOR COOKING. MANUFACTURED IN JUNE 2008. PROBLEM IS- IT WONT HEAT-----FAN WORKS -LIGHT WORKS--TURNTABLE WORKS-----IT JUST DOESNT HEAT! COULD THERE BE A FUSE OR SOME KIND OF ELEMENT TO REPLACE?????
  • hadjiwarre Mar 19, 2011
    THANKS SO MUCH !!!! BUT A NEW MAGNETRON COST $150. SO I WILL PURCHASE A NEW MICROWAVE SOON.THANKS AGAIN !!!
  • 4,472 Answers
Most times when it won't heat that is a sign of a problem with the magnetron itself. Usually the magnetron's have a longer warranty then the microwave itself. I would consider following this link and setting up a service call to check out the microwave.
https://www.whirlpool.com/service/service.jsp?country=US&lang=en&brand=WP
Thank you,
Lee
Posted on Mar 18, 2011
  • Lee A.
    Lee A. Mar 21, 2011
    Right, if it's not under warranty then most often the price of the magnetron means replacement is the smartest economical solution.
    Thank you and have a great day.
    -Lee
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
Model GT4175 has no display on keypad and
Sounds like the fuse is blown. Take outer casing off and look and see if the fuse is good or not.
Aug 11, 2009 | Microwave Ovens
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
Jan 13, 2008 | GE Advantium SCA2001BSS Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
140 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
