Question about Cycling
The rear hand brakes are locked up. How do I repair this myself. The pads are still in great condition, no signs of wear and tear. Thanks for any help, Marti
  • 22 Answers
You have setting the rear brake rods & than screw tight it.
Posted on Mar 18, 2011
What cause front dis brakes to wear out every year?
Make sure that the calipers are sliding freely on the brackets(check the rears also,because the calipers are tied to the one on the opposite corner of the car in the hydraulic circuit).If everything moves freely,then your best bet is to switch to ceramic pads.(I used to change the pads on my Grand Caravan yearly until I went to ceramics,now I can't remember the last time I had to change them).City driving puts a lot more wear and tear ont the pads,but another cause could be this:a LOT of drivers rest their foot on the brake pedal.Even very light pressure can cause excessive wear,so make sure to drive with ONE FOOT unless you have a manual trans!(a telltale sign of this is abnormally high wear on the brake pedal pad).
May 11, 2012 | 2004 Chevrolet Malibu
2007 freestyle rotor warping
Inspect the wheel hubs for flaws in the rotor mounting surfaces that could prevent rotors from seating properly. Also, check the wheel bearings for slop, roughness or other signs of wear. If the bearing does not rotate smoothly and keep the rotor on center, the rotor will wear unevenly. (Also, pay attention to unusual rumbling sounds when cornering or sudden jerks while braking; these indicate possible wheel bearing problems. The jerking may be caused by the bearing locking up momentarily when the brake changes it load forces.)
Another thing to look at if the problem recurs: take a quick peek at the instrument panel to see if the low traction warning is on. If it is and the road conditions are good, the anti-lock braking system has a false trigger condition. This could be caused by an off-center rotor or a sensor fault. The hard part is identifying which wheel has the problem
Jun 12, 2017 | 2007 Ford Freestyle Limited
I have a Lexus LS 460-2007 with 45000 miles on it, should it need breaks at this time?
you can't estimate brake wear with mileage, dirver style, conditions such as highway, city, hilly country, all have a different effect on brake wear, i have seen some drivers only get 15,000 miles and others over 100,000, best to get them inspected once a year and replaced when 60 to 70% worn
Sep 13, 2010 | 2007 Lexus LS 460 L Sedan
My hand break light stays on while driving. Is this a warning light or is there just faulty lighting?? Thanks
If you have done about 30+k Miles , you may need brake pads.Examine for leaks, Check brake fluid resevoir (yellow cap usually) for fluid level. Do not top up if no leaks are present. It may just be the early brake pad wear indicator telling you it's time to replace the pads. Removal of the front wheels and inspect the brake pad condition for wear. Good luck If pads are worn, topping up fluid will put out the light BUT not solve the wear problem so inspect first.
May 03, 2010 | Suzuki XL7 Cars & Trucks
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
At what mileage should the rear brakes be replaced? Is it common for the rear brakes to be replaced at less than 22,000 miles on a 2007 Sonata gls?
Most of the stopping power goes to the front of the car. You usually go thru two sets or sometimes three sets of front pads before you need to change the rear brakes. It sounds odd the rear brakes need to be replaced at 22,000. havee the front brakes been replaced before?
Sep 17, 2009 | 2007 Hyundai Sonata Limited Sedan
What is involved in an 80k service?
Change the oil and filter.Change the plugs and air filter.Change the fuel filter.Check washers wipers,Horn.Check all lights check brake fluid.Check power steering fluid.Check all belts for wear and tear.Remove wheels and check brakes for wear.Check tyers And check suspention ball joints for wear.Make sure the timming belt has been changed.If not have it changed.
Jul 24, 2009 | 2004 Volkswagen GTI
Rear brakes on muy 2000
Generaly speaking, if you're getting about 2 years out of a set of pads, then you're doing ok. The grinding you're hearing is the pad material wearing off to the metal backing of the pad due to normal wear. Also make sure you do a caliper service and clean and lube the slide pins, as well as the saddle where the pads sit in the bracket.
Nov 17, 2008 | 2000 Ford Mustang
Remove and replace back brake pads
Never did beetle brakes, but many others, always used a big 'C' clamp. It will help to open the bleeder on that wheel when you compress the clamp. countrycurt0
Oct 10, 2008 | 2007 Volkswagen Jetta 2.5 Sedan
Brake warning lining wear
Yes the parking brake uses a small set of brake shoes that act on a drum built into the rear rotor. There is no wear sensors on the parking brakes. There are however wear sensors on the front and rear brake pads. If your brake pad warnig light is on I would have the service brake pads inspected. 82210425
Jun 16, 2008 | 1998 Mercedes-Benz E-Class
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
