Question about Sony VAIO PCV-W20 PC Desktop
How do I insert memoy into my Sony Vaio PCV 9913. RAM memory
myob247
  • 1342 Answers
SOURCE: trying to open the case for Sony VAIO PCV-RX540
Go Here
Scroll down to Overview & General Info
Posted on Apr 25, 2008
  • 69 Answers
SOURCE: What kind of memory does the Sony Vaio PCV -7744
From the model number you were asking about it says that it takes pc2700 ddr333 RAM It has 256MB standard and is upgradable to 1GB between the two sockets for RAM. Thanks
Posted on Mar 18, 2009
Dr Geek MD
  • 201 Answers
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: Noisy fan when downloading larger files
Well this really isn't much of a problem, as the fan turning on shows that it is doing its job. It turns on due to processor having to run faster, naturally raising its temperature, so the fan keeps the processors temperature within operable limits.
Posted on Jul 11, 2009
SOURCE: how do i upgrade the ram on sony vaio pcv-v1/g,
Very easily! With the unit on it's stand, tip the screen forward as far as it goes (About 15deg past vertical). This uncovers 2 Philips cross-head screws, one on each end of the black box that hangs off the back of the screen and contains the memory,processor, fan etc. Now the top of the black box can be lifted off. Inside is an aluminum box with the lid taped (!) on. Remove lid, and inside are 2 memory slots. One will have a 500mb mem card in it. The other is empty. Fit you new 500mb in the empty slot for 1gb total (the max). Don't forget to use some form of anti static protection and of course unplug it from mains electricity before you start!
Posted on May 17, 2010
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How do i reboot my sony vaio computer model number pcv 9913 i dont have operating disk
You reboot it by simply unplugging it from the mains and restarting it.
You reinstall Windows using a generic Windows disk and the key on the label on the case. You will have to add the drivers yourself later.
May 27, 2011 | Sony VAIO PCV-W20 PC Desktop
Been given a sony pcv9913 but no manual where do i get on
Been get a VAIO PCV-9913. But no manual and i cant watch TV troughtout TV Tuner. I can i solve it?
pauloladeira@hotmail.com
Apr 05, 2011 | Sony VAIO PCV-W20 PC Desktop
Sony pcv 9913 will not boot up, just sits on a bla...
hi, well change the ram may help thats the first thing need to be check laptoprepairdirect@live.com
May 20, 2010 | Sony VAIO PCV-W20 PC Desktop
When i turn on my computer it come on but it don't show any thing it just bring the turn on sound pls what can i do. sony pcv-9913
Interesting. Can you hear the hard drive starting up at all? Has the laptop been used in any way that may stop it from functioning?
Dec 29, 2009 | Sony VAIO PCV-W20 PC Desktop
How to upgrade RAM memory what to buy and is anything else be upgraded before this
It is a very simple thing to upgrade your Ram which is a great idea since you have only 512 MB. I suggest you buy at least 1 GB or more if you can afford it. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a reputable site I use all the time. This will require a download of the scanner tool which is perfectly safe. http://www.crucial.com/
Nov 05, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Apr 26, 2009 | Sony VAIO PCV-W20 PC Desktop
Sony VAIO PCV-W20 PC Desktop Logo
429 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
