Question about Maytag Washing Machines
I have a top load Maytag washer which I have had for about 5 years. For some reason, for appriximately the last year, it seems to have problems with balance when spinning. I have to be more cautious in how I load the clothes than I did in the past. Some time there is still off balance during spinning. I think the washer may not be totally level but supposedly there are leveling legs which are supposed to auto correct. Can you tell me what the problem is?
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
I mostly answer front load problems but ' out of balance' is a common problem with both!
I don't believe the legs do 'auto correct'; they can be adjusted to correct.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 18, 2011
Maytag PAV2300AWW has oil in dust cap.
There is alot of oil in a transmission it could last another 4 or 5 years. the only problem is the oil eats the belts up.
Feb 14, 2013 | Maytag PAV2300 Top Load Washer
I have a Maytag Atlantis top load machine. It is 7 years old. I have very dark oil dripping from under the machine at the bottom edge of the front. I am assuming the gear box is gone but wanted to confirm...
Sorry to confirm your suspisions but its leaking oil from the transmission and its exxxpensive to replace the transmission. And sad but true the good ole days of dependabilty of the maytag is gone espically since 5 years ago Maytag was bought by Whirlpool. a Whirlpool is a good machine but nothing was good as the old Maytag's
Aug 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Should we buy a cabrio?
Its recommended to buy whirlpool washing machine they are having the spares for their old model also when compared other brands
May 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire Front Load Washer FAFW3574K - Is this a good washer, and how long should I expect it to last?
There are many things that can facotr into the life of a washer.
How many loads a week do you do?
What are the size of the loads?
What is the quality of the water?
Under many circumstances you can reasonably expect your washer to last 8-10 years.
The factors mentioned above can change that higher or lower depending mostly on your useage..
Heatman101
Mar 10, 2010 | Washing Machines
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I think my Maytag MAV6200AWW washer has a bad tub seal & bearing
if you have had this unit for over 5 years Then it is TOTALLY NOT worth the repair - if it is only a year or 2 old then call MAYTAG and they may offer a parts/labor concession. average life is 5-10 years now as sucky as that is!!
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
