Someone tripped on the power cord to the Extensa 5430 while it was being used. This caused the power jack in the laptop to become very loose, and now it will not charge. New motherboard, try to open it up and somehow re-secure the jack (I'm A+ certified), or just SOL? Money is a VERY BIG issue. Nobody has a job right now, and this computer was the way jobs and leads are pursued, as well as staying in contact with the network of people.
    Sergeant:
  • 235 Answers
Sounds like you need a new dc jack. Go to ebay and find it. It's relatively inexpensive. Once you get it you will have to solder it. Good luck and have fun!
Posted on Mar 18, 2011
Toshiba laptop is shutting down message but does not caanot use the laptop
If the computer functions when plugged in with or without the power cell, you ok. Just replace the battery. Many times the power plug is at fault. This happens over time because the power cord may accidently be pulled out, (like if someone trips on the cord and pulls it from the laptop). The end of the power cord may become loose, and if so it will not make 100% direct contact between the power transformer and the line in to the computer. You cannot let the power cell (Battery) die. Some computer require a healthy Cell be operational in order to start up and function normally.
Jan 14, 2018 | Toshiba Computers & Internet
How do I fix loose ac jack on acer extensa 5620z?
If your laptop is under warranty or has a service contract, I would send it in for service according to the terms of sale. If your ac jack is loose you should check the cord in case the end is damaged and if your power cord isn't damaged you need to check the screws and connection and that's going to require removing the battery and the bottom cover of your laptop. It isn't difficult to replace most of the hardware in the Acer laptop, but you'll be exposing circuit boards and wires and there are all kinds of things that can be damaged if you're not careful, so I don't recommend taking apart your laptop unless you are certain you can replace the hardware without damaging other sensitive components. I really suggest that you have someone qualified in computer repair take a look at your laptop.
Also, once you open the back cover or take apart anything on your laptop you will void your warranty. most laptops have stickers and tabs placed on your laptop and once you remove the sticker it causes damage to the sticker and it lets the manufacturer know that you've attempted to repair it and that voids the warranty.
Once you check those see if the battery works, it may need replacing. Good luck!
May 30, 2014 | Acer Extensa 5620 Notebook PC
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
Acer Extensa 5230E laptop not charging
More than likely you need to check your DC Power Jack where the power cord plugs into the laptop. If it is loose or broken, it will not charge the battery and will not boot.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 20, 2012 | Acer Extensa 5230E2913 Notebook
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
Toshiba laptop power failure after yanking power cord
Hello.
Sounds like you already determined it, but if you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
Hope this helps.
May 09, 2010 | Toshiba Satellite Pro P300 Notebook
The pin in the middle of the power jack has come out so battery can no longer be charged
Your best bet is to purchase a new power cord, you can pick one up from Amazon for about $20.
http://www.amazon.com/ASPIRE-Equivalent-Replacement-Power-Adapter/dp/B001KVWHKY
Jan 26, 2010 | Acer Aspire 5050 5430 Laptop
Jack is loose where charger plugs in
This same thing is happening with my acer laptop. I sent it to the company about 3 months ago, and it happened again. I really need my laptop and cant take a month without it. I advise sending it in to be fixed to your laptop company.
Good luck (:
Jun 29, 2008 | Gateway (1532852) Power Supply
Power supply very loose in back of laptop
This is a very common problem with laptops. The DC power jack becomes loose from too much strain on the power cord or in some cases from poor design. If you are not comfortable messing with it yourself you will have to take it to a repair shop. I would also try a different power cord first.
Do it yourself #1
Do it yourself #2
Apr 05, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
