Question about HP Compaq nc6120 Notebook
How do I replace the left shift key that has popped off?
I hav laptop acer brand wea the lfet side shift key not working wea as right side shift key is proper working..i need away out to hav the left shift key wrking
I would replace the keyboard. They are fairly inexpensive from that auction site flea bay and a video on how to do it is available on utube. Search for your make and model with the words 'replace keyboard' after it in the search box.
Dec 23, 2013 | Acer Computers & Internet
Left shift key not working
Hi Marcy,
Check that the key depresses all the way (same amount as other keys next to it). If so, then the most likely problem is that the keyboard has failed. You can have the keyboard replaced fairly easily.
Keyboard for the Dell Vostro 1520 costs $20 or less depending on where you buy. You can view YouTube videos on how to replace the keyboard or have someone professionally replace it for you.
Keyboard replacement on YouTube
Aug 06, 2012 | Dell Vostro 1520 Laptop
I turn off the car, but key will not come out of ignition. Lock on shifter doesnt work. I can shift without pushing button on shifter. This is an automatic.
We had this problem on 06 and it is the shift button that doesn't pop out. You may be able to pull it out so you can remove the key for now. We had ours fixed under warranty (replaced)
Jun 16, 2010 | 2008 Chevrolet Hhr
My gear shift i stuck in park
You can get it out of park as a temporary fix by popping off the little cover to the left of the gearshift, then pushing down on the lever beneath the cover with a flathead screwdriver (or skinny key) and then shifting out of park.
May 15, 2010 | 2000 Honda Accord
LOOSE LEFT CTRL AND SHIFT KEYS
Generally, the keys on a portable keyboard are non-repairable. The keyboard is a Customer Replaceable Unit (CRU) and if under warranty, Dell should send a replacement, If out of warranty, Ebay is a good source for a keyboard and they generally run about $20
http://cgi.ebay.com/New-DELL-inspiron-Keyboard-630M-640M-E1405-E1505-6400_W0QQitemZ260372955660QQihZ016QQcategoryZ31512QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 23, 2009 | Dell Inspiron E1505 Notebook
Shift question mark not working
Keyboards can go bad - luckilly they are cheap. It may be time to replace it.
Jul 18, 2008 | Televison & Video
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
Gateway keyboard shift key creating special characters when used
This is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://www.sportmachines.com/keyboard/
Jan 30, 2008 | Gateway 2520915 Keyboard
HP Compaq nc6120 Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
