Question about Microwave Ovens
10 yr old hotpoint Microwave model #RVM1325BW will not heat, vent,clock, touch pads all working.Hust no heat. If this needs to be replaced what model # should I get for the same dimensions?
    Problem Solver:
  • 9 Answers
I would say that your heating element has gone out. I don't know exctly what model you have, but I would guess it to be about 1.5 Cubic Ft., and a replacement would probably run somewhere around $150 to $200. There are many brands, but if I had no cost to consider, I'd probably go with a GE or Kenmore. Hope this helps.
Posted on Mar 18, 2011
NEED PARTS. BROKEN HANDLE.
need part number for hotpoint rvm1325bw 002 door handle
Apr 11, 2010 | Hotpoint RVM1325BW Microwave Oven
My microwave turns on, the fan and light work, but it doesn't heat the food.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the blower)))
Oct 30, 2009 | Hotpoint RVM1325BW Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
Danby DMW753W 800 Watts Microwave Oven Problem
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | Danby DMW773 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
