Question about Kitchen Ranges
I am trying to find the top oven/grill glass for my oven 050551134 clear glass white surround.
  • johnc288 Mar 18, 2011
    it is a stoves panache 600sidlm
    Problem Solver:
  • 9 Answers
What is the brand name of the range? Is this the model # of the range or replacement part?
Posted on Mar 18, 2011
  • Mary Williams
    Mary Williams Mar 18, 2011
    Sorry, I don't know the brand, but I did do a little searching around; however, to no avail. I would suggest just searching the internet until you find someone who handles that product, which I'm sure you've already done. Wish I could help more; nevertheless, good luck!
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Hello i am cleaning my parkinson cowan cooker and i have took the gill door off and i cant put it back on, just wondering if you have instrouction please? thankyou
Position the glass between the metal plate and the white plastic handle contraption and secure with 4 screws. This is not very stable so hold the glass securely.
Pull the grill door forward 4inches, place the glass assembly with the lugs at the bottom in the corresponing holes on the grill door.
Move the top white handle and glass thingy towards the top of the grill door.
The secret to how this works is to make sure the sticky out things with holes in at either end of the metal plate/glass/plastic handle go under the lip of the grill door.
Place the remaining unattached to anything 2inch wide metal plate above the lip.
All the holes will line up. The screws screw into the affore mentioned sticky out things with holes in.
Thats it.
If you by any chance want a new website look at this.
Nov 06, 2010 | Parkinson Cowan SG553 Dual Fuel (Electric...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Older model - belling 356 double oven - unable to get grill to work
The microswitch on the right of the top oven is stuck in. Open the top oven door and you can see the switch on the right. It has a small black rubber cap on it. To solve this, loosen the right top and bottom screws of the brown panel and lever the white panel slightly to the right. Tighen the screws and the switch should go in and out as you push and release it. The grill will now come on when the door is open.
Apr 01, 2008 | Kitchen Ranges
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
