Old Proton 420 clock radio needs battery to hold memory of stations and time. What battery do I ask for to replace old one? I want to buy battery before I take radio apart.
5 Suggested Answers
SOURCE: Proton Model RS-420 clock radio lost power back-up
The battery is located on the display circuit board at the front of the unit. It's a bit of a pain to get to.
You'll need to open the case, unplugging the wiring harness plugs so you can take the two halves apart. Next, remove the strip of circuit board at the top where the snooze/alarm and other top button switches are. Then you will be able to get to all of the screws holding the display circuit board to the front of the case. The battery is soldered to the board. I'm not sure what type or voltage it is, but it's probably a single-cell NiCd at 1.2v. I think the best replacement would be a supercapacitor but I need to figure out exactly what the battery is first.
It's a great radio that's worth fixing. If anyone can tell us what the battery is, please post! Mine says "860" on it.
Cheers,
- Phil
Posted on May 31, 2009
yammy_alf
  • 666 Answers
SOURCE: Proton 320 clock radio won't stay off. Comes back on by itself!
check power switch if not block and i good position. and also monitor by multitester if the continuity of that switch cut in off position.
Posted on Apr 13, 2010
  • 15 Answers
SOURCE: Lost my 'off' ' button on my Proton 320 clock
No need to worry, you can buy adjustable knobs and at radioshack and ebay. However if the button broke off you need to go in and replace it.
Posted on Oct 05, 2010
  • 13 Answers
SOURCE: tuning lamp on Proton 320 clock radio
The original is an incandescent 14V 30mA bulb. Hard to get. Much easier to substitute a Blue or Green 3V 30mA LED, in series with a 470ohm 1W carbon resistor, to reduce the 14V to 3V. The LED will last almost forever. Don't forget that an LED is polarity-sensitive, and must be connected appropriately Long-leg to RED, and Short-leg to BLACK.
Posted on Jul 20, 2011
Lost my 'off' ' button on my Proton 320 clock radio!
Sep 29, 2010 | Proton R5A Clock Radio
Theres no memory to the clock and radio settings
Hi and thank you for using fixya:
IF your clock is not staying on time make and your stations are going out of memory check your car battery the terminals might be loose making your radio to reset itself every time the batteries moves.
Good luck
thanks
Jun 21, 2010 | Durabrand WD810
When i switch off dewalt dco11 radio the station memory is lost
Does the clock lose time too? 2 AA batteries under a door inside the battery compartment. Change them, reset time and stations.
Feb 06, 2010 | Dewalt DC011 AM/FM Radio
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Oct 07, 2009 | Dewalt DC011 AM/FM Radio
Need to replace the starter on the 97 mitsubishi Diamante, how hard is it to remove and replace ?
To replace the starter you need to;
) Note if you have an anti-thief system and now to reset it if the battery is disconnected.
) Note the radio station selections if they are not saved if the battery is disconnected.
Now
) Disconnected the GROUND connector on the battery.
) Disconnect the electrical cable on the battery.
) Remove the 2 bolts holding the starter on. Remove the harder one to reach first.
) Pull the old starter out.
) Insert the new starter.
) Replace the bolt. Insert the easier bolt first.
) Tighten the bolts.
) Replace the electrical cable.
) Reconnect the GROUND connector on the battery.
) Reset any radio, clock or anti-thief systems.
) Return old starter for a core charge refund.
May 25, 2009 | 1997 Mitsubishi Diamante
89 Maxima clock and radio needs to be set
You have a blown fuse for the memory for the radio & the clock.
Sep 12, 2008 | 1989 Nissan Maxima
Cheers,
- Phil
Apr 30, 2007 | Proton R5A Clock Radio
 Grubhead
Grubhead
