Question about LG 55LE5500 55 in. HDTV LED
Trying to connect wireless router. is asking to insert security key of ap. what does that mean?
  • 902 Answers
You need the security key for your wireless router
Posted on Mar 18, 2011
What does error code 51332 mean
Your wireless security settings in the Wii are not the same as the one in the router that you have. See here for more information.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51332&system=Wii&locale=en_US
May 10, 2011 | Nintendo Wii Console
Were do i find the pin number
If by pin you mean the KEY for wireless SSID then you have
Log in to the AP by connecting a PC with AP via wired cable.
Point to web address: http://192.168.1.1 and input user and pass (IP may change due to config)
Go to wireless->Security
Change the key in Passphrase and you are good to go..
Mar 12, 2011 | Trendware TRENDnet TEW-432BRP 54Mbps...
I cannot connect to the internet with my wireless router MSI RG60SE. I keep getting an error and to insert a security key. How can i get this security key?
You need to access the router and look for the network key. For you to access your router you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "admin" and the default password is admin. Go to the router settings page and check the Network Key (Security Key). You can also personalize the network key for you to easily remember it.
Thanks for using Fixya.
Jan 27, 2011 | MSI (MS6848) Wireless Router
How to get internet.
You can try to connect to the internet wireless using your wireless router however, you need to know the Network Name (SSID) and the Network Key of your Router. You can find that on the router settings page. Heres how you can connect your Wii
1. Go to Wii settings
2. Internet connection settings
3. Search for an AP (Network Name or SSID)
4. Input security key (Network Key)
Jan 24, 2011 | Nintendo Wii Console
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
WEP password for Westell 327w
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;} Slide 1 .O {color:black; font-size:149%;} .O1 {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC !important;} a:visited {color:#B2B2B2 !important;} Open Internet Explorer & in the URL:// bar type: 192.168.1.1 or dslrouter.
Select Wireless and then select Security from the Configuration
menu.
If you use WPA-PSK or WEP
wireless security, you must configure your computer’s wireless adapter for the security code that you use.
At the Wireless Security drop-down menu, select the desired security option
WEP: Selecting this will enable you to set up WEP security on the VersaLink. The AP card
supports 64-bit, 128-bit, or 256-bit WEP encryption. If WEP is selected, any station can connect to the AP (as long as its SSID matches the AP SSID). If wireless security is disabled, the risk of someone nearby accessing the AP is maximized
type in the desired WEP Password....do not forget to save...
Oct 27, 2009 | Westell Wirespeed VersaLink...
How do I set up my wireless Belkin F5D7050, I no longer have the CD. My computer has Windows Vista?
1. Hard wire your pc to the router/modem using ethernet cord / cat 5 cable or use usb storage to download the driver to this link
http://web.belkin.com/support/article/?lid=en&pid=F5D7050&aid=5381&scid=0
2. Install the driver/software by executing the file.
then follow this:
SymptomNot able to go online only with the wireless connection.
ResolutionTo address the problem, use the following steps:
  1. On the Belkin Wireless monitor utility click on the tab AP List .
  2. Select the encrypted network that you wish to join. Click Connect.
  3. This will take you to the New Profile page . Enter a Profile Name .
  4. On the next page, you will see the network name, the network type and the transmit rate. Click Next.
  5. This will take you to the page that will ask you to select the Authentication Mode. This will be OFF by default. Select Open System or Shared Key depending on the network.
  6. Then select 64-bit or 128-bit encryption depending on the configuration on the Router/AP. Click Next.
  7. On the next page, select Input Method , which will be Hexadecimal (0-9,A-F) or Passphrase.
  8. Select the key index and enter the keys or the passphrase depending on the configuration on the router/AP. Click Complete.
CauseYou are not able to connect to a secured wireless network because the router/AP (what is this?) is encrypted.
SummaryWireless networks by their very nature are not secure because data is transmitted across open (i.e., air) media. This allows unintended “listeners” to receive the data. WEP (Wired Equivalent Privacy) is used in a wireless network to secure the signals and hence the data.
Jul 12, 2009 | Belkin (F5D7633UK4A) Wireless Router
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Wep/wpa
Hi, doesn't really matter which, what is important is what ever it is you choose, it should be the same/consistent all through out the wireless network/system. example, if you choose wep $ key is 12345 in your router/AP, then all you wifi clients should be using wep $ key of 12345. Choosing or not choosing what wireless security mode to use is not preventing you to log unto the internet, they are designed that you can securely communicate/acces the router/ap and if granted acces, the router/ap will then be your gateway, so first you must be connected/logged on to the router/ap before you can share its internet. Hope this be of some help/ pls post again how things turn up. Kind regards.
May 21, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
LG 55LE5500 55 in. HDTV LED Logo
77 people viewed this question
Computer Repairing
Computer Repairing
