Question about Saeco Spidem Villa
How can I increase the water temperature? - Saeco Spidem Villa
  • 22 Answers
You could setting the thermostat level
Posted on Mar 18, 2011
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
Water heats up then trips off red button
The lit red button may be an indicator that the water temperature inside the water heater flow channel has become too hot. If the outflow facet is adjusted to allow more water outflow (opened more) the water temperature should drop some and therefore with increased water flow, the temperature inside the water heater will also decrease. Or, if there is a manually adjustable outflow valve on the water heater, adjusting it to a more open position would also decrease the internal temperature.
Sep 17, 2015 | Water Water Heaters
Rheem 21vp40 1
Copy following links to identify type of thermostat, and see how to adjust temperature on that specific thermostat, and see other ways to increase amount of hot water
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Add a comment and describe if water heater is gas or electric, and add what other problems you are experiencing.
Jul 14, 2013 | Water Heaters
How do I adjust the faucet to get the water hotter?
If you have a hot water heater there's where you turn you heat up for your water if its hot oil its on the furnace boiler
Mar 05, 2013 | Plumbing
Normal wash cycle is over 2 hours?
Hello there
If your dishwasher's cycle times are too long, check these: Water pre-heating Cycle not completing Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater. Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jul 19, 2010 | Kenmore 16919 Built-in Dishwasher
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
Intermatic electric water heater timer only gives enough hot water for a 7 minute shower. How do I increase this time?
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
May 14, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Nov 12, 2008 | Zanussi Dishwashers
Dish washer
Water pre-heating
Water pre-heating
May 14, 2008 | EuroTech EWF150 Front Load Washer
Saeco Spidem Villa Logo
137 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
