Question about Husqvarna Garden
Have a model#-137-husky.has it got a adjust.to control bar oil flow?at present is over suppling bar lube.thanks!
  • Husqvarna Master
  • 2,239 Answers
The pump is not adjustable, it is very unusual for them to over oil, the pump shaft can only rotate at the speed of the engine, it is calibrated to cope with a 15" bar, it is more likley it is leaking out of the oil tank.
Posted on Mar 18, 2011
How can I adjust the oil flow to the bar of chainsaw?
Look-up the UT-43103 IPL. There is no provision to adjust the oil flow. Suggest checking the oil lines for loose or broken areas; also could replace the oil pump. These are very inexpensive parts. here is a link to the parts list and source for the parts.
Homelite UT43103 Electric Chain Saw Parts
Dec 06, 2014 | Homelite Garden
Does the husq 440e have an oil adjustment on it?
Hi mwaltz48,
Yes, Huskys have a screw adjustment on the bottom, under the chain sprocket assembly.
While looking at the bar side of the saw, turn it over and you'll see a screw that has 3 positions.
Turn the screw to the right will decrease the oil flow, left to increase it. If you put a longer blade on, you should increase the oil flow.
A way to check your oil flow is to run the saw with the blade pointing at something light, such as a freshly cut chunk of wood, or the end of a log, etc. You should see a light line of oil appear.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The oiler quit on my husky 460, I replaced the plastic gear on the crank shaft, but it still is not oiling. What is the next step to get oil flowing again? Thanks ! R.J. Rose
Was the plastic gear damaged? The pump itself may be in trouble. Did you check for a plugged filter in the tank? Have you started the engine with bar and chain off? It should ooze out oil from the side port where the bar fits up to. If so, the small oil passages that run from the large holes out to the chain groove on each edge of the bar may need to be cleaned. This saw should have an oil volume adjustment screw on the bottom near where the chain returns to the engine. Turn it CCW to increase flow. Test the volume adjustment by running the assembled saw tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Nov 07, 2010 | Garden
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Oil does not lube chain on my chain saw, huqvarna, any ideas
It appears from the IPL and OM this saw does not have an adjustable oiler.
OM example here (2005 - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501001.pdf
IPL example here (2005 - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501901.pdf
I know you have done this, please verify whether or not you get the ooze with the saw running.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). I am seeing many non-adjustable oilers malfunctions, please contact Husky, there may be an unannounced repair.
HusqvarnaUSA Contact Us.com
If you try the repair yourself it has an outboard clutch (oiler behind it), this will help with removal. Your IPL is also beneficial.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
The OM and IPL links I provided may not be your saw. If not yours can be found here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 28, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do i adjust the bar oil
turn the saw upside down, there is a little screw that only turns a quarterturn, turn it counterclockwise for the maximum flow
Nov 25, 2009 | Husqvarna 450 e-series 18" Chain Saw
Firstly the oil was pooring out of the saw. I found some sort of adjuster on the underside which showed a + or - for oil lube. I could nt really see in so I used a screwdriver to alter what looked like a...
Correct, many saws have an oiler adjuster screw, which normally takes a smaller flat screwdriver, and the adjuster should only turn a portion of a turn, let's say 1/3 to 2/3 of a turn.
I can imagine that if your screwdriver were too large, it may be difficult to align with the adjuster screw.
Nov 21, 2009 | Husqvarna Chain Saw 20" Bar
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
119 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
