Question about Homelite Garden
Hello My Homelite XL (Red) 14 Inch, Chainsaw sometimes locks down, when I try to pull the starter rope to start the engin, and you can not turn the engin, The only way I can start it is to losen the spark plug to release the compresson, and crank it, When I turn the switch off to stop the engin to tighten the spark plug back, and tighten it, then some times I can pull it and crank thr engin, and some times I can not it is still locked down and I cannot pull and turn it. Is there a compression release valve, to release the compression while cranling, If so where is it located, I have taken the engin out of the housen and can not find one. If not whot could be the problem? Please answer E-Mail Address abaget@att.net Amos Baggett Temple GA 30179
  • 3,740 Answers
Only certain models of Homelite XL chainsaws have a compression release valve. See this picture:
http://img177.imageshack.us/img177/7717/vol4xl9xx002.jpg The only models that do have the valve are distiguished by a G in the details of the model (right column).
If yours is one of the models with the compression relief valve they are either a button near the intake mainfold or and automatic valve net the exhaust port. All others use ports in the cylinder head for decompression. If the cylinder head gets coated with carbon and these get blocked you can have the symptom you describe. You might be able to use an old spark plug (Cylinder head pointed down) then remove the muffler and fill the cylinder with Chemtool B-12 to attempt de-coking / de-carbon of the head. Let is sit for a day or 2 with the chemtool in the cylinder. After that remove the old spark plug, clear out the residual chemtool and then try a start. This works about 60% of the time... the others the head has to be removed and soaked in a solvent tank.
Before you do all of the above with the muffler off... look for any signs of tiny holes in the exhaust port of the head that may be blocked. Use a knife blade and scrape a bit diring the search. A word to the wise... do NOT us a scribe in any of the holes if there are any.... I have broken off the scribe in the hole an ended up buying the customer a new head! Try as I may I just could not drill it out and by the time I would have had the machine work done to make it right.. the cost was nearly the same. The Chemtool will also clean these ports if you keep the cylinder filled.
One last oh by the way....Remove the old spark plug to drain the chemtool... do not let it get into the crankshaft seals as it will trash them if exposed to the seals for more than a few minutes..
Let me know how it goes.
Thanks for choosing FixYa.
Kelly
Posted on Mar 19, 2011
How do I start a Homelite little red XL
usually by pulling on the rope .after priming and choking with the kill switch turned to the run position .sometimes it helps to remove sparkplug and give it some fuel there and quickly put plug back in tight .
Nov 30, 2015 | Homelite Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    My Poulan 14" chain saw has become difficult to
    If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
    Jan 09, 2011 | Poulan 14" Chainsaw
    Can anyone help with replacing the existing pull cord in a homelite 330 chainsaw?
    Complete instruction and easy to follow.
    R² Starter Rope by SmallEng.com
    http://www.youtube.com/watch?v=eRyy3MlsjVo
    If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
    Lou
    May 03, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
    Cannot pull the pull rope. Feels like motor is froze but when I pull the pull rope cover off the pull rope pulls freely and I can turn the fly wheel by hand easily. Put everthing back togeather it will not...
    PISTON COULD BE SEIZED DUE TO LOW OR NO OIL MIXTURE,ALSO IT COULD HAVE FUEL IN THE CHAMBER,FIRST REMOVE SPARK PLUG--NOW TRY TO PULL IT--HINT,STICK A SMALL SCREWDRIVER IN THE HOLE AND SEE IF THE PISTON RAISES AND LOWERS,,IF IT WILL RAISE/LOWER BY MANUALLY TURNING THE CRANKSHAFT,THEN THE PROBLEM IS IN YOUR INNER PULL ROPE ASSY.(THERE ARE DOG EARS INSIDE THAT SPIN OUT AND GRAB THE FLYWHEEL WHEN IT TURNS)
    Sep 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
    Do not know how to start my chain saw
    First the chain should be tightened properly before starting. When you pick up on the chain midway of the bar it should pull away from the bar about 1/4". The proper mix of oil & gas in the fuel tank & Oil for the chain in the oiler tankk is needed, If so, locate the on/off switch & turn it to "on". Pull the choke lever out. Depress the throttle trigger & engage the latch for the trigger. With the saw held firmly in place, pull the starter rope until the engine hits. Then move the choke to half & pull till it cranks. move the choke lever to the run position.
    Aug 19, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
    Chainsaw won't start. Can't pull starting cord out
    Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
    Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
    Thats a little strange.
    Only thing that comes to mind is someone else had access to it and swapped out a plug that is too long for your short plug, Check plug type in owners manual.
    maybe on sunday their 4 wheeler wouldn't start and this was quick fix.
    Take off the chain cover or starter and see if it turns back and forth almost one full turn with a sudden stop at both ends of rotation. (Hitting plug)
    if this is ok get back to me.
    Bill
    Feb 24, 2009 | Homelite Garden
    We were putting a new pull starter rope on an older homelite 240 chain saw and accidently dropped the cover. The spring came out. Now we are having a very hard time trying to get it back in. Is there an...
    Wear saftey glasses...
    hold the middle coils and keep pulling the outer coil slowly hold the spring with long nose pliers. keep tightening it up un till its smaller than the case hole...
    make sure its on the right side..
    Jan 12, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
    Garden Logo
    107 people viewed this question
    Top Homelite Garden Experts
    roeb
    Roland W VanLue
    Roland W VanLue
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
