Question about LG WM-0532HW Front Load Washer
I have a indeset wil 103 front load washining machine,the machine won't pump out water.
  • 472 Answers
Need to check the drain pump area located on bottom of unit,, either something is in drain pump or hose that connects to drain pump. if all that looks ok then you most likely have a faulty drain pump assembly....
Posted on Mar 18, 2011
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My wil 103 indesit wont pump out the water and the drum stops spinning quite quickly prior to spin, removed pump, guy at repairers says pump fine and it may be the board?
If you have a test meter, and feel competent to do this, then select a spin cycle, and having set the meter to mains A/C voltage, test across the 2 wires going to the pump, if you are getting a supply, then it should be reading approx 240 volts.
If no reading, then, yes it could be the board, or a broken or loose connection.
Another way to do it is to select a Drain only cycle if there is one, and you should hear the pump running.
If you can, and it is still not draining, then check the outlet hose for a possible blockage.
Please rate my solution.
Thanks.
Nov 07, 2009 | Zanussi FLE1416W Front Load Washer
Washing machine not heating water
Washin machines "do not" have heating devices, make sure to check your water heater and turn it back on to get your water heated.
That will get you back in hot water business.
GOOD LUCK.
Aug 30, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine has broken down
try to put your washer on a drain and see you can hear the pump workng. you should hear a buzzing.if you dont it mite be your pump that as gone. to get the water out pull whasher out near your back door if poss and lie the drain pipe flat the waser will then empty. if there is a buz then you could have a blockage. but if not a pump is no more then 25 pound and are not that had to do
Jun 24, 2009 | Indesit W 123 Front Load Washer
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Water will not drain from washine machine
it could be your lid switch or your water pump
Mar 17, 2009 | Kenmore 22642 Top Load Washer
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
