Question about TP-LINK TL-R480T+ Broadband Router 2xWAN, 3-port 10/100 Switch, Supports Load Balancing
I am using two WAN connections through TP-LINK TL-R480T+ Broadband Router, I assigned IP 10.0.1.1 to this router. I want to ask what will be the default gate way which will I have to type in optional setting of router. As I am facing slow browsing and some time "page not found" problem on clients.This problem solved instantly when i connect my client direct to WAN without router. I think DNS is also problem when I browse via router.
I'm a user 4 the same load balance product, your 2 ADSL lines must have difrent IP with difrent submask than the IP you assigned 4 TP Link-TL R480t+ (10.0.1.1 in Ur case), lets say 1st line connected to the Line through a Dlink router has an IP 192.168.1.1, this will be WAN1, its config will be as follows:
WAN Port: WAN1
WAN Connection type: Static IP
IP Address: 192.168.1.2
Subnet Mask : 255.255.255.0
Defult Gateway: 192.168.1.1
MTU Size : 1500
Pri DNS: (add the DNS here)
Sec DNS : (add the DNS here)
the second line shuld be the same way with difrent IP & difrent subnet (for example IP=192.168.2.2, Subnet Mask = 255.255.255.0 - for the router connected to the 2nd line IP 192.168.2.1 which will be the defult gatteway for WAN2)
hope this answers your question
Hosean Kobara
Posted on Nov 20, 2011
  • 1,591 Answers
There are a number of bugs that are fixed in the latest firmwares.
You can get the firmware updates at
http://www.tp-link.com/en/support/version.aspx?mid=01030305&pid=775
I'm assuming you're using the load balancing feature here...lol...when you called it a router rather than a load balancer, it threw me off for a second with the 2X wan !
You'll need to look at the little diagram on the page to see if you have a ver 1, 2, 3 or 4 before you update the balancer / router.
You've probably run into an issue where you are getting ports assigned that the router needs for itself, and the new firmware addresses that along with many other little bug fixes (at least the ver 3 does).
If the firmware update doesn't do it for you, please don't hesitate to either reply to this post, or post a new problem...but if you make a new post, please remember that I likely won't be picking it up, and whoever does, will know nothing of the information here, so you will have to provide all information again in the new post.
Posted on Mar 18, 2011
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
Set port forwarding with 2 adsl lines
NAT port mapping sould only be configured on the node that is connecting a LAN network (private address) with a WAN network public adddress (not 192.168...)
Aug 07, 2013 | TP-LINK TL-R480T+ Broadband Router 2xWAN,...
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
Disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Mar 06, 2012 | TP-LINK TL-WR1043ND Router
After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Nov 20, 2011 | TP-LINK TL-R480T+ Broadband Router 2xWAN,...
Trying to set up for first time a TL WR 1043 ND router. Mode 1 : with provided CD Router connected to cable/telephone modem After CD installation and during router configuration verification process the...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Apr 20, 2011 | TP-LINK TL-WR1043ND Router
TP-LINK TL-R480T+ Broadband Router 2xWAN, 3-port 10/100 Switch, Supports Load Balancing Logo
2,171 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
