My washer is one year old (GE) and i started having a mildew/mold smell coming from the machine so I had GE repairman out - he recommended using a product once a month BUT the smell is back. Any other thoughts? I keep the door open and wipe out for excess dampness - is there supposed to be a check valve on the washing maching discharge hose?
    Brigadier General:
  • 6,277 Answers
(try this!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to pursuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Awful smell! I drain it every cycle, I use the washer cleaner, everything! I am so sick of my towels smelling awful.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Mar 24, 2010 | LG WM-2277HW Front Load Washer
My clothes smell! Less than one year old GE front load!
That happened to me too. Check for mold and mildue around the inside seal, if you find anything BLACK, clean it up. Also, pull out the drawer where the laundry detr is and clean it as well. Also, when the washer is not in use keep the door open, this will cut down on the mold and mildue.
Sep 23, 2009 | GE WSXH208A Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Affresh
Try reliable parts. There are many locations across Canada and the US. You might also get the Affresh tablets at an appliance retailer or hardware store but I'm not sure.
http://www.reliableparts.com/
Here are some (mixed) reviews of the affresh tablets. http://www.buzzillions.com/dz_708669_whirlpool_affresh_washer_cleaner_reviews#reviews
but like I said in my post, you may have to run a few full cycles with the tablets to get a smelly washer clean and then maintain it by using the product every 1-3 months or so.
You could also try this product: http://www.smellywasher.com/
This is an review on their site:
"I have to tell you I am very pleased. Having an acute sense of smell, I always get teased for smelling odors that others don't. For about 6 months we've had a mold/mildew odor in our 1 1/2 year old washer. I found your site on the internet and ordered SmellyWasher.
I can tell you my husband was amazed at all the mold coming up and I felt "vindicated". Here is the other interesting side of things. Coinciding with the smell of the constant mold/mildew for the last 6 months has been the fact that I have been constantly sick. I came down with cold after cold after respiratory sickness along with the rest of the family since Thanksgiving. I was literally getting sick of being sick. The last bout was bronchitis with whooping cough.
After I did the cleaning out of the washer with your product and removed all the mold/mildew, I have NOT gotten sick since and have had 2-3 weeks without any respiratory problems. I have come to believe that it has something to do with me cleaning out the mold, and no mold residue on towels or clothing. My husband is coming to believe this also. It's so nice to breath in and NOT smell the mold.......
I love your product and have told several people about it.
Oct 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer smells like poop!? why
As you may well know in Europe we have been using front loaders almost exclusively for 15-20 years now. New European machines now only have one fill valve (which is cold) because the machine heaters are so efficient it is greener not to have a hot fill. Generally as a result, machines have a build up of 'soap scum' within the soap box, outer drum and fill and emptying pipes. Bacteria including e-coli builds up within the machine and so manufacturers recommend a boil wash with bleach only every three months. To save yourself money a cap full of white vinegar poured directly into the drum followed by a boil wash does exactly the same job and is a greener alternative. The soap box can be easily removed and washed out by hand.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
Maytag HE 4t/ Kenmore Elite Smartwash Serial# CST0411376 MODEL# 11045088403 TYPE 199 712 CN/AP MY WASHER HAS A AWFUL ODOR INSIDE THE TUB. I HAVE CLEANED IT OUT WITH ALL KINDS OF CLEANERS TO TRY...
The following link provides guidance on how to maintain a front loader to keep the mold, mildew and odor away:
These are recommendations provided by the manufacturer. Most important of all, keep the rubber bellow clean and clear of debris and make sure you leave the door slightly open when not in use. This will minimize the build up of any mold or mildew and allow the tub to air out. The odor typically comes from the the residual water that stays in the wash tub under the basket and small articles of clothing getting stuck in the rubber folds of the door bellow. (I once found 17 socks stuck in a customer's washer and they wondered why it smelled so bad). NOTE: It is NORMAL to have residual water in the wash tub. If you do not routinely use a hot water setting, run the washer on a sanitary cycle about once a week, or so, with a small amount of bleach to get rid of any bacteria. Since some users conserve and only wash in cold water, they do not bacteria get rid of any bacteria inside the wash tub. I personally own one of these washers and have never had any odor or mildew problems in 8 years by following this simple advice. If you have any further questions/concerns please let me know. I hope this helps you.
Aug 06, 2008 | Washing Machines
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
