Nintendo DS Lite Console Logo
Posted on Mar 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nintendo ds cant log on the access point - Nintendo DS Lite Console
Anonymous
Level 2:
  • Expert 211 Answers
  • Posted on Mar 19, 2011
Anonymous
Expert
Level 2:
Answers
211
Questions
0
Helped
32266
Points
443
Maybe You have a weak signal!
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
I need to know how to connect my ds to the enternet can yhu tell simply so i can understand
You must either have broadband internet access and a wireless router or you can connect your Nintendo DS at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2.Turn on your Nintendo DS and click on the wrench icon. This will take you to the system settings.Go to page 3 and select "Internet".Click "Connection Settings".Click "None" to the right of "Connection 1".Click "Search for an Access Point".Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DS should now be connected. If its locked then do the same thing but click on it and enter the code.
  • PCHELPSTER007 from youtube
  • 0helpful
    If you try to get wifi and it says"the access point's security settings are not supported by the nintendo ds" what do you do
    The only solution to this problem would be to change the type of security used on the wireless network in question. You would have to log in to the router or wireless access point with a computer and locate the wireless security settings, then change the encryption type used on the network.
    The access point's security settings are not supported by the nintendo DS
    This means you've got a WPA/2 security connection on your router/access point, whereas the Nintendo DS only supports WEP or open encryption.
    You can:
    1) change your security from WPA to WEP on your router
    2) Purchase a used nintendo wifi stick
    3) Set up a second router or access point with WEP security specifically for your DS
    1helpful
    Ok so i was trying to get an access point on my pokemon black version and i have wifi at my house but when i searched for an accss point it popped up wit a remark that said "The access point's...
    The Nintendo DS can only connect to 802.11b networks with WEP encryption (see here). Make sure your access point is 802.11b with WEP encryption in order for your Nintendo DS to be able to connect to it. Than you can try connecting it again.
    Good luck.
    Hello, how do i get facebook on my nintendo dsi xl? ???
    Connect to a wireless network that the Nintendo can detect nearby. If it is your home network, determine what the SSID is, identify it on your list of access points, and then enter the access number to communicate with that network. Once you've establish communication with a network you can connect to the Internet and log in to Facebook.
    Web setup
    With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
    1. Tap Nintendo Wi-Fi Connection Settings
    2. Tap one of the Connection slots
    3. Tap "Search For An Access Point"
    The Nintendo DS will then display the name of your wireless access point.
    If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
    If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
    Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
    If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
    NOTE: All information taken from http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp
    I have a nintendo ds and i have nintendo wifi but in gts it said ihad no connection and it sent me to this website help
    You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access.
    1. Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings.
    2. Go to page 3 and select "Internet".
    3. Click "Connection Settings".
    4. Click "None" to the right of "Connection 1".
    5. Click "Search for an Access Point".
    6. Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected.
    7. If you are planning on playing games online with your Nintendo DSi and have WPA security, you will have to set your router to WEP security.
    8. To do this, get back to the "Connection Settings" screen mentioned in step 4.
      Click "Advanced Setup".
      Click any button that says "none".
    Thanks for using Fixya.
    Good Luck and have a nice day.
    My WiFi problem
    Please confirm the manufacturer and model for the router being used? The router in the heading of this message does not appear to have wireless capablity.
    Secondly in terms of your sisters machine assuming it has an ethernet port have you tested it using the cable just to make sure there are no (software) firewall issues on her computer affecting access to access the internet.
    Sorry I have no Nintendo DS knowledge specifically. I may try to research the issue after the router and laptop issues are resolved.
    Are there any other wireless devices (computers) currently working correctly with your wireless router/access point?
    Top Nintendo Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Aron
    Sean Wright
    Sean Wright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
