Question about Bialetti 8853 Espresso Machine
My Bialetti stove top espresso maker has started making a high pitched sound as it percolates. It seems to be coming from the little pressure valve on the side. When pressure is applied to the mechanism it stops. Do I need to replace the part or is there some way I can fix it myself?
JohnnyBeans
  • 223 Answers
SOURCE: Bialetti will not make coffee
I would check the grind size you are using. Maybe it is ground too thin and the pressure cannot push through.
Also, remove screen and washer and make sure passage to the top is clear.
Shop Bialetti's Soon on:
www.CeriniCoffee.com
Posted on Nov 20, 2007
SOURCE: My espresso maker, a Bialetti, has its top very stuck to its base
i had the same issue. i ran the base under very hot water from the tap for one minute. This forces the metal to expand and loosen, making unscrewing the base much easier.
Posted on Jun 06, 2009
  • 7 Answers
SOURCE: How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Posted on Jul 17, 2009
Zlobomir
  • 225 Answers
SOURCE: I have just blown the valve on my bialetti
The valve no, it is dangerous. Steam under pressure is a bomb. If you can detach ?unscrew? the old valve and find a new one, it will be fine.
Posted on Nov 08, 2009
Testimonial: "thanks for fast response"
  • 66 Answers
SOURCE: Need a copy of instruction manual for Bialetti
hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Posted on May 21, 2011
Steam relief valve releasing pressure before and during the making process.
make sure your water level is not too high. needs to be just under release valve inside
Aug 15, 2013 | Bialetti Coffee Makers & Espresso Machines
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
Apr 19, 2011 | Bialetti 4cup Stainless Steel Espresso...
Hello I've had my stove top Bialetti for many years, and its worked beautifully. However, recently I've had a lot of problems with it. It is taking much longer for the coffee to brew, and in fact it does...
I do not supect the basket just make sure it is not blocked with limescale or other debris as this will reduce the flow of steam through your coffee grounds.
if this is ok then check the pressure release valve on the lower chamber it may be open or defective see if steam is coming out of it when your use your machine if you do not get pressure in your lower chamber it can not lift all the water to the top.
i do not know if the pressure release valve is a replaceable part.
Nov 13, 2009 | Bialetti 20-9 Stove Top Espresso Machine
I have just blown the valve on my bialetti cappuccino maker, can I reuse it?
Nov 08, 2009 | Bialetti Stovetop Espresso Maker Espresso...
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
Coughing coffe
Try a lower flame and screw the top to the bottom as tightly as possible.
Mar 17, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Nov 20, 2007 | Bialetti 8853 Espresso Machine
Bialetti 8853 Espresso Machine Logo
70 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Mark Cheong
Mark Cheong
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
