Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I HAVE A GE SPECTRA ELECTRIC STOVE MODEL J BP78W0B1WW... THE OVEN DOOR ON THE RIGHT ,,,THE SPRING ARM,,, CAME DISLODGED FROM THE KEEPER... THUS THE OVEN DOOR DOES NOT OPEN AND CLOSE PROPERLY WITHOUT FALLING TO THE FLOOR... I CAN NOT GET THE SPRING ARM MECHANISM BACK IN ITS HOOK HOLDER... I WILL TRY TO DISCRIBE THE HOLDER THAT THE SPING ARM FITS INTO::: SIDE VIEW::: TWO PIECES OF METAL 1 1/4 IN WIDE BY 4 IN LONG SPACED ABOUT 3/8 IN APART,,, HELD TOGETHER BY THREE 3/8 IN LONG RIVETS LIKE... FRONT VIEW::: 3/8 IN WIDE 4IN LONG WITH A CUT OUT SECTION IN BOTTOM THIRD WHERE THE SPRING ARM WOULD FIT THROUGH AND HOOK ON THE TOP RIVET LIKE HOLDER... THE ARM HOOK PRETRUDING FROM THE OVEN DOOR HOOKS UNDER THE TOP RIVET AND RESTS ON THE BOTTOM TWO RIVETS...
  • 76 Answers
SOURCE: General Electric stove top burner does not light
whalerpaul, To get access to the gas burner valves you have to: 1.UNPLUG THE POWER CORD 2. Remove all burners 3. There are 2 screws under each burner, remove all of them and lift up the top panel 4. Remove all knobs, remove screws holding the manifold panel (two on top and four on the bottom) 5. Carefully pull out the manifold panel and remove two wires from the oven light switch, put the manifold panel on side Part number for the right front gas burner valve is WB21K12 and you can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542247749&type=10&subid=
Posted on Jan 14, 2007
  • 833 Answers
SOURCE: ge spectra gas stove top not lighting
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
Same problem here. The ignitor went bad. The part + labor from a local appliance person set us back $201.35 !!
Posted on Mar 28, 2008
reg501
  • 413 Answers
SOURCE: Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Posted on Jun 06, 2008
SOURCE: GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Posted on Aug 01, 2008
General electric spectra electric oven, door doesnt close complete. Heat from the oven comes out.
please,i need help!i have a problem about my GE spectra electric oven door is loocked i cannot open at all,what i can do?to be open?
Mar 29, 2011 | GE Spectra JBP78 Electric Kitchen Range
The glass broke need to replace it.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Feb 03, 2011 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
After oven cleaning,
GE to8 (oven) control. Part replacement.
Mar 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
