Question about Adtran NETVANTA 1234 POE 24PT LAYER2 SWCH POE 1700595G1 Ethernet Switch
How do you reset adtran netvanta 1234 back to factory?
2 Suggested Answers
  • 33 Answers
SOURCE: Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Posted on Mar 20, 2009
How do I factory default adtran netvanta 1224st?
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
May 19, 2011 | Adtran NetVanta 1224ST PoE w/ UK power...
I do not know the password to acccess adtran 3430 router. how can I reset the router to reconfigure
Thank you for using FixYa
The default password is 'password' and then 'admin'
uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
Apr 29, 2011 | Adtran Netvanta 3430 Router
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Nov 24, 2010 | Adtran NetVanta 3200 Router
Can you please advise how to do the password recovery on Adtran Netvanta 1335
Call ADTRAN Technical Support at 1-800-4ADTRAN and they will be happy to assist you.
Oct 08, 2010 | Adtran NetVanta 1335 Router (1700515E2)
I have an Adtran NetVanta 1335 Router that keeps shutting itself off everynight after my store does all it downloads. I have put it onto it own power supply, any assistance to help keep it up would be...
You need to enter maintenance mode (a web interface) and check the power settings from there as some of these have the ability to sleep etc at preset times.
sort of added security and green all in one function
Aug 31, 2010 | Adtran NetVanta 1335 Router (1700515E2)
Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# boot
Oct 20, 2009 | Adtran NetVanta 3200 Router
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
May 25, 2009 | Adtran NetVanta 3200 Router
Adtran  NETVANTA 1234 POE 24PT LAYER2 SWCH POE  1700595G1 Ethernet Switch Logo
2,489 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
