Question about Black & Decker Garden
I have a PW1600, PW1750 elec. power washer. Turns on but no pressure.
4 Suggested Answers
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
  • 18 Answers
SOURCE: the soap will not pick up on my Black and Decker
u need to not use the soap use the soulation un pressure use black tip
Posted on Jun 27, 2009
  • 7 Answers
SOURCE: i have a black & decker pressure washer model
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Posted on Sep 12, 2009
Does not have high pressure
Either the pump is bad or worn out or the pressure relief valve is stuck open and needs to be closed. No kinks in water line to unit?
Feb 24, 2016 | Campbell Hausfeld PW1750 Electric Pressure...
DO NOT KNOW HOW TO USE SAOP/SOLUTION CONTAINER
soap dispensers only work wit no or low pressure nozzels. when you have high pressure nozzles there is too much back pressure for the soap dispenser to function ..
Sep 14, 2013 | Campbell Hausfeld PW1750 Electric Pressure...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Cord is rapidly "minced" up
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
Jul 09, 2009 | Black & Decker String Trimmer Cordless 12"...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Electric power washer shuts off
Sounds like a coil.Run till it shuts off, then check for spark.If there is no spark you will need a coil.
Mar 17, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Mar 11, 2009 | Garden
Garden Logo
109 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
