Question about Hotpoint Washing Machines
La cuve se promene il est po fix comme il manque un support ou ressort pour la stabiliser
    Brigadier General:
  • 6,277 Answers
Pardon- en Anglaise!
Hi from retired Englishman in SW France
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 18, 2011
Bonjour, mon problème c'est avec une
j'aurai besoin d'un peu plus d'info sur model de camera,et ce que vous tenter de faire
si la camera est debrancher de l'ordi ,et si l'ordi demarre normalement sans la camera,
vous pouver me contacter par email (aselectronique1@gmail.com.
ainsi on pourra peut-etre trouver une solution je ne comprend pas les #232, 233
merci sicerement alain.
Jan 01, 2011 | Canon Video Cameras
Tip
Messageries instantan?es : bien d?buter avec Windows Live Messenger ...
Messageries instantanées : bien débuter avec Windows Live Messenger
MSN a changé de nom et est devenu Windows Live Messenger. Son utilisation est toujours aussi intuitive, n'hésitez plus à vous lancer. Retrouvez notre tutoriel pour bien l'installer et faites vos premiers pas dans le monde des messageries instantanées.
L'installation : facile comme un clic Il faut avant tout ouvrir un compte chez hotmail ou MSN c'est-à-dire une adresse mail, pour pouvoir se connecter. Il s'agit de votre compte Passport qui vous servira d'identifiant pour entrer sur le réseau. Vu le nombre d'utilisateurs, qui augmente considérablement avec le temps, il devient de plus en plus difficile de choisir un nom qui ne soit pas déjà utilisé. Soyez créatifs mais n'oubliez pas que le nom que vous choisirez sera communiqué à toutes les personnes avec qui vous souhaiterez communiquer. Depuis peu Il est également possible de se connecter avec un mail qui ne provienne ni d'hotmail ni de msn et on peut aussi bien directement se connecter via le web sans rien télécharger (mais sans avoir toutes les options). Ensuite il vous suffit de télécharger le logiciel ici.
Suivez les indications pour l'installer, puis double cliquez sur l'icône dans le bas de votre écran à droite. Entrez l'adresse de messagerie et le mot de passe enregistré avec votre compte Passport. Il reste à vous faire connaître auprès des personnes qui ont déjà MSN.
1.jpg Cliquez sur l'onglet Contacts en haut à gauche puis sur ajoutez un contact Pour ce faire, cochez la case en bas et entrez l'adresse de messagerie du contact que vous souhaitez ajouter. Le contact s'ajoute automatiquement dans votre écran principal, il vous suffit ensuite de le placer dans la catégorie qui vous convient (amis/collègues/famille/autres contacts...)
Avant de pouvoir lui parler, sachez qu'en l'ajoutant vous venez de lui envoyer un message lui demandant s'il accepte d'être ajouté dans votre répertoire. Si la personne accepte (ce qu'elle devrait normalement faire) vous recevrez un petit message de confirmation. "X a accepté de devenir votre ami". Ce petit message vous confirme que vous ne vous êtes pas trompé de messagerie en envoyant votre message.
Premières conversations Une fois tous vos contacts ajoutés, retournez dans la fenêtre principale de MSN Messenger, double-cliquez sur le nom d'un contact en ligne pour lui envoyer un message. Vous écrivez dans la partie inférieure, une fois envoyé le texte apparaît dans l'écran du dessus et vous pouvez suivre la conversation en continu.
2.jpg Notez qu'une utilisation répétée de MSN est une bonne techniquepour apprendre à taper plus vite sur un clavier. Il ne vous reste plus qu'à entamer la conversation. Vous pouvez voir sur la photo les coordonnées du contact ainsi que les options offertes par messenger... envoyer des fichiers, démarrer une conversation audio ou vidéo. Vous pouvez parler à autant de personnes que vous le souhaitez, double cliquer sur un contact ouvrira à chaque fois une nouvelle fenêtre pour parler en tête à tête... Vous n'êtes limité que par le nombre de vos contacts et votre capacité à gérer plusieurs conversations en même temps.
Autre possibilité : vous parlez à une personne et vous souhaitez inviter un autre contact (ou plusieurs) à participer à votre conversation. Là encore, la simplicité règne. Il suffit de repérer la petite icône "inviter" qui se trouve juste au dessus du nom de votre contact dans la fenêtre de discussion. Vous tombez sur une autre fenêtre regroupant la liste de vos contacts en ligne, sélectionnez la personne que vous désirez inviter...et c'est parti. Recommencez autant de fois que vous le souhaitez.
on Oct 09, 2010 | Microsoft Windows Live Messanger
Ecran noir
Le Fran?ais n'est pas ma langue maternelle, mais j'essayerai d'aider. Si l'?cran est noir et il n'y a aucune lumi?re sur l'affichage tel que la lumi?re de puissance, je v?rifierais la premi?re fois que le fusible n'est pas entr? dans la prise. Si c'est correct, alors essayez le moniteur sur un ordinateur ou un ordinateur portable diff?rent pour voir si c'est un manqu de la carte graphique. S'il n'est pas, alors je pense que le condensateur de puissance est entr? dans le moniteur et aura besoin repalcing
Dec 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Probleme electrique avec starter betterie afablie toujour
Salut, Bogosse6897 il convient de noter que, pour "CORRECTEMENT" diagnostic de probl?me de d?marreur ?lectrique, il est «imp?ratif» que vous commencez avec une batterie compl?tement charg?e 12,5 volts ou mieux et ?tre en mesure de passer un test de charge appropri?e, et les suspects habituels sont: 1. Les bornes des accumulateurs ont des connexions desserr?es ou corrod?es. 2. Les c?bles de batterie d?fectueuse en raison corrod? ou cass? le c?blage interne au niveau du connecteur de c?ble de c?ble en particulier "NEGATIVE", qui doit ?tre v?rifi? aux extr?mit?s "Les deux". 3. Batterie tension, 12,5 volts ou mieux, le disjoncteur principal ? l'interrupteur d'allumage du fusible de s?curit? / allumage du module TSM / TSSM ? l'arr?t du moteur / commutateur de fonctionner sur le bouton de d?marrage pour le relais de d?marreur au fil vert qui se connecte au sol?no?de du d?marreur a baiss? de plus de 02/01 volts. 4. Avec un voltm?tre connect? ? la batterie, le commutateur d'allumage sur la position, le coupe-circuit dans la position de marche, le bouton de d?marrage enfonc?, l'engagement de d?marrage ne devrait pas porter tension inf?rieure ? 8-9 volts. Si une tension plus basse est produit un test de charge correcte de la batterie doit ?tre r?alis?e avec un appareil de contr?le de charge afin de valider l'int?grit? de la batterie ou le remplacement de la batterie. 5. D?faut relais de d?marrage, v?rifier la continuit?. 6. d?fectueux d?marreur sol?no?de, v?rifier la plaque de contact et des chaussures pour excessive ?lectrique ?rosion / gravure, remettre en ?tat si n?cessaire ou inverser la plaque de contact et d'utiliser l'arri?re vierge. V?rifiez chaussures de contact pour ?tre l?che. Remplacer l'?lectrovanne si la fonction n?gative est encore un r?sultat final. 7. d?marreur d?fectueux, banc de d?marrage d'essai avec une batterie de 12 volts si la v?rification de la fonction n?gative, D?contamination et contre-d?pouille segments armature de commutateur au besoin, v?rifier les segments avec une sonde ohmm?tre chacun et le segment ? c?t? de lui pour les courts m?trages. Avoir l'armature test? avec un growler et sur le terrain des bobines, et la plaque de brosse avec un ohm-m?tre pour ouvre, des shorts ou des motifs. Remplacer les balais si moins de 0,438 "Il est g?n?ralement moins cher ? r?viser / remettre en ?tat un moteur de d?marrage que d'acheter un nouveau. Pour plus d'informations sur votre probl?me et pr?cieux t?l?chargements "libre" que vous aurez besoin s'il vous pla?t cliquer sur les liens ci-dessous. Bonne chance et bonne journ?e. Motorcycle Message Board Motorcycle USA
http://www.starbikeforums.com/forums/49-v-star/20121-v-star-650-click-click-click.html
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jun 02, 2010 | 1999 Yamaha V Star Classic
Bonjour ma xbox 360 clignote rouge( 3 LED) et ne fonctionne plus.que faire?et qui contacter en cas de panne? il y a t-il un numéro en france? merci
e74 ou erreur de rrod signifie qu'il y a une issue de matériel. Ce que vous devez faire est une réparation très simple et bon marché. regardez sur ebay pour des kits de réparation de bride de x, ce sont juste quelques mâles et la plupart des vendeurs incluent un bon guide dans la façon faire le mod/difficulté. ce qui cause le rrod ou l'erreur e74 est la bride de forme de X sur le dessous ou le conseil de mère se pliant et mis-formant entraînant la boule soudant sur le gpu/unité centrale de traitement légèrement fondant et formant des fissures de délié dans la soudure. Le kit de x-bride s'appliquera plus de pression au gpu/unité centrale de traitement et tour de déconnecter les ventilateurs et d'allumer le xbox et de lui permettre de surchauffer au sujet de la fonte les joints à rotule de soudure remplira fissures de délié. Selon quel morceau est l'issue vous peut également avoir besoin des 2000 pistolets de chaleur de watt au lieu d'employer la méthode de chauffage finie (le morceau de gpu). Le remplacement des garnitures de la chaleur sur le radiateur par la pâte thermique qui vient avec le kit gardera le refroidisseur du gpu/unité centrale de traitement et vous n'aura pas cette issue encore. Assurez-vous svp que vous achetez le kit qui vient avec les rondelles en nylon soumises à un traitement thermique pendant que les lavages en acier de ressort échouent !. Les prises de réparation environ 1-2 heures J'espère que ceci vous aide dans la fixation xbox J'ai dû utiliser un traducteur d'Internet pour traduire l'anglais au frech ainsi à moi appologise pour n'importe quoi non traduit correctement
Nov 01, 2009 | Microsoft Xbox 360 Console
Je n'ai plus de tonalité quand je téléphone, plus de son
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
Jul 28, 2009 | Palm Treo 750v Smartphone
Help me
le message "sa manque fichier usb.sys" vous indique que Windows est defectueux, vous devez reinstaller Windows.
ici il est explique' comment reinstaller ou reparer Windows(reparation, mise a jour de version ou mise a niveau):
Comment faire pour installer plusieurs mises à jour ou correctifs .
Réparer Windows XP - La solution
Windows XP - Installation et mise à jour
Nov 05, 2008 | Microsoft Computers & Internet
Iris problem with PT-AX100U projector
le probleme est du par les pivots de l`iris qui manque de lubrifiant. il a deux pivots a lubrifier, le premier se lubrifie sous le projecteur dans le compartiment de la lampe.
il est de couleur brun et il a un petit resort autoure de lui, il est en plastique. prendre un micro
tournevis et le faire fonctionne. il doit revenir sur lui meme rapidement,lentement pas bon il faut
le lubrifie. seulement une petite goutte suffit.
le deuxieme est plus complique,il faut ouvrir le projecteur. les vis sont sous le projecteur indique
par des fleches. il en a une autre sur le dos .attention il est difficile de separer les couvercles
on peut voire le pivot sous une petite grille de metal il est brun lui aussi
ps prendre le tounevis pour applique le lubrifiant atf dextronIII
Oct 23, 2008 | Televison & Video
Panne sur mon camescope dcr trv285e
Les message est indique qu'Il est possible que les capteur bobine il se defectue. Il doivent changer a complet un system chargement de cassette en Anglais est { LS chassis assemly } Il vous faul un Technicien forme par Sony ou chez Sony meme pour la reparer et ca depend ou etes vous dans quel pays Je ne sais pas combien ca va couter dans votre pays. Si vous etes en AUSTRALIE ca coute a peu pres entre $250 a $350 Australie dollars
J' espere que cela vont vous done quelque idee
Bone change
PS: Est ce que vous essaye un autre cassette quelque fois de cassette devient lourd en tournant alors il se montre de meme message
N' hesite pas de me contacter si vous avez besoin plus d' info come service manuel ou schematic pour la reparer vousmeme ou quelque chose d' autre
Sep 02, 2008 | Sony DCR-TRV285E Digital-8 Digital...
La lumiere du reservoir d eau reste toujours allumer . aucun eau dans le reservoir et j ai vidanger l eau mon appareil est un danby dpac10030. c est un climatisateur deshumidificateur et humidificateur...
J'ai le même problème avec le même modèle. Tu dois vider le réservoir du compresseur. Il n'y a pas de bac. La sortie se trouve en arrière tout au bas de l'appareil. C'est un bouchon que tu dévises. Attention, ce n'est pas celui pour la hose ou le bac arrière, mais il est vraiment tou en bas caché en desous des 2 entrée\sortir pour l'air. Il n'est pas montré dans le manuel. Si tu as ce problème, c'est que ta pompe pour remonté l'eau en brisé. Ton manuel p52, tout est expliqué.
"Fonctionnement de climatisation"
Si tu le vide, tu vas durée environ 2 heures avant de refaire la vidange.
Jun 09, 2008 | Televison & Video
Washing Machines Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
