I was using my laptop and it automatically powered down. I thought the battery was flat so plugged into the mains. When I switch on button nothing happens, there are no lights on. Green light on AC adapter but no power seems to be getting into laptop.
    President:
  • 3,278 Answers
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter may be faulty and need replacement.
Or, unfortunately, your motherboard could be faulty.
Hope this helps.
Posted on Mar 18, 2011
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
Asus eee pc 1000ha wont take charge from adapter
try unplugging from the mains, remove the battery, hold the power button down for 30 seconds. plug the mains adapter in and try turning on. if it doesn't work then it's either the power socket or the mainboard.
if it does work, then try it again with the batter in. if it stops working then your battery's shot.
Apr 13, 2013 | ASUS Eee PC 1000HA Notebook
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
I have a seond Aspire 5742Z laptop which has been working perfectly fine until just now. I switched it off and went to log back on. The power button and the power indicator have lit up but seems to be...
Sometimes these laptops get stuck in a loop. Try removing the battery and the AC power cord. With these still removed, open the lid, and hold down the power button for 30 seconds.
Replace the battery, and plug it back in to the mains, and press the power button again. Hopefully this will clear the issue.
Jul 23, 2011 | Acer Aspire 5742Z-4200 Notebook
My Toshiba Equium A200-196 will not switch on - power light is on and it's plugged into mains but pressing the on/off switch, nothing happens!
hello
try this: remove your battery and plug directly to the main power w/out battery. second remove thebattery press and hold the power button for ten seconds and put the battery back and power on your laptop.
thank you
Mar 11, 2011 | Toshiba Computers & Internet
I pluged in the power supply and nothing is happening. The small yellow batery icon came on near the screen and nothing else is happening
Remove the mains power lead and then take out the battery. Hold down the on/off button for 30 seconds to dispel any residual power.
Plug in just the mains lead (AC adapter) and see if the machine will boot on mains power only. If it does let it boot up and then shut it down again. Remove AC and reinsert the battery, plug in AC power again and see if it will boot with the battery in.
If it boots up the problem is sorted, if not then there is a problem with battery so you would have to use it on AC only until you find a replacement battery.
Please post back if need anymore help.
Good luck and regards.
Jan 11, 2010 | Dell Latitude D505 Notebook
Packard Bell Easy ONE DC Laptop Failure..
check this remove the battery , then insert it after some time , then check
Sep 03, 2009 | Computers & Internet
Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
Nov 25, 2008 | E-Machines T1360 PC Desktop
Switching on the laptop
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
Nov 15, 2007 | Dell Inspiron 6400 Notebook
My laptop wont turn on at all,is different to the other problems on here.help
Try removing the battery (instructions in your manual). Now run the computer with just the new charger. Does this work? Try holding down the power button for 10-20 seconds.
Nov 08, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
David Payne
David Payne
