Question about ViewSonic N3751W 37 in. LCD Television
I have a 22' viewsonic tv. i'm getting a "channel blocked" message with four boxes showing. tv is about 2-3 years old. prior to this the tv will power off then on with a blank white screen. you can still hear the program. the only way to solve this is to unplug the tv and replug again. then it will work. but this time I push the channel up and down button before the tv could turn itself off. this is when I got the channel block on all stations with no sound.
SOURCE: viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Posted on Jan 04, 2008
SOURCE: Viewsonic n4060w does not turn on
Welcome to our world... http://www.fixya.com/support/t285490-viewsonic_n4060w
This thing needs to go to a state attorney general if Viewsonic isn't even will to provide parts for these pathetic LCD TVs.
Posted on Jun 25, 2008
Roshan89
  • 271 Answers
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Posted on Dec 17, 2008
HI I AM A TECH. I WORK FOR A COMPANY THAT REPAIRS LCD TV'S. IF YOU HAVE SOUND AND NO PIC YOU WILL NEED AN INVERTER BOARD THERE IS A WEB SITE CALLED SHOPJIMMY.COM THEY MAY HAVE IT
Posted on Mar 17, 2009
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
hi,guys with shutting down viewsonic t.vs.
As you power up your t.v continously press input button on your tv
until it powers on.Sometimes last all evening,someyimes for 5 minutes.
your welcome
Posted on Dec 01, 2009
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
Viewsonic N1930w
Check its tuner. If tuner is faulty, this kind of fault can occur. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
May 10, 2013 | ViewSonic N1930W 19 in. LCD TV
I have a view sonic N2230w and its lock it says menu lock and I cant get it unlock. What can I do?
Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
May 12, 2011 | ViewSonic N2230w 22 in. LCD TV
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
My ViewSonic N2230w 22 in has a menu locked and it cant change to a different input and im trying to unlock it but i cant i need to get it to unlock
Nov 06, 2010 | ViewSonic N2230w 22 in. LCD TV
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
How do i eliminate a black rectangular block on my 25" zenith tv?
You have the closed-captioning turned on and set to "text" mode. It's easy to do on Zeniths because many of their remotes have on button just to control the captioning. Go to the caption settings and turn it off or set it to "caption" mode if you want to use it. Then the box will be gone.
(What's happening is that in text mode, the screen is blanked out in the area where the text would go, but there isn't any text being sent by the station. On channels where no captioning at all is used, the box never shows up.)
Jan 19, 2009 | Zenith B25A11Z 25" TV
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top...
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Jun 02, 2017 | Televison & Video
ViewSonic N3751W 37 in. LCD Television Logo
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
