Indesit 24 in. IDL500 Built-In Dishwasher Logo
Posted on Aug 02, 2008
Spares for Indesit IDL500 Dishwasher
A Mouse ate the rubber seal of the dishwasher Door. now I need to replace it where can I purchase such a thing.
what is the product code
thank you
Sam van Niekerk
Western Cape
South Africa
[email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
406
Points
My dishwasher will not heat up to temperature during cycles. Water remains cold, what parts could be a problem and howwould I test them
Indesit IDL500 not heating (element is fine)
It's usually behind the control panel you have to remove the screws on the door
Indesit dishwasher IDL505 green light flashing water not entering the machine
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
My dishwasher is working fine . but the water is cold . is it a big job to fix . thanxs.
Some have electrical heating elements that could be tested with a multi meter on the ohm scale. If the meter indicates that the element is open circuit it needs replacing and you should take note of the water seal and mounting of the element.
Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Indesit idf 125 dishwasher
you don't need salt in the dish washer?
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
4answers
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
