Question about Microwave Ovens
Micro stopped in middle of time set.no power, like a fuse popped.checked surrounding plugs appliances,such all ok, as the breaker, is there a Reset?
  • 22 Answers
If you are check his relay wiring, i think your problem are solve
Posted on Mar 18, 2011
I blew a fuse and now my dishwasher and oven will not come on. Is there a reset button for these appliances?
Some makes do, but normally you get something on the display. Did one of these appliances blow the fuse? In which case you need to find out what made the fuse blow. Do you have house fuses as opposed to breakers? Disconnect both appliances. Check the fuse or breaker, plug one item at a time. The one that is likely to blow the fuse is the dishwasher because of the water.
Mar 23, 2018 | Microwave Ovens
Convection oven suddenly stopped working in the middle of cooking. Is it a fuse?
HI THERE IS ONE IN THE PLUG AND AN INTRNAL FUSE IN SIDE YOU WILL HAVE TO OPEN THE SIDES OF THE OVEN TO GET AT IT SOME HAVE MORE THAN ONE FUSE IN SIDE
Jan 12, 2016 | In Microwave Ovens
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
NO POWER, POPPED CIRCUIT
Two possible causes.
First (and most likely) the circuit is being overloaded. This kitchen circuit may be shared with another appliance (like the refrigerator) which is drawing enough power when both are running to trip the breaker. A Typical kitchen circuit is 20 amp with #12 wiring. So an 1800 watt microwave might draw 13 or 14 amps while a fridge compressor kicking in can surpass 7 amps before it levels off. If this is an older home the kitchen may have a 15 amp circuit with #14 wiring. If the circuit is a 20 amp you will have to split the appliances onto separate circuits. (Under code a kitchen must have a minimum of 2 separate appliance circuits). If it is a 15 amp you might be able to split them as well or may be looking up upgrading the breaker and the wiring from 15amp #14 to 20 amp #12 (but you could still have the same problem).
The other possibility is a short or loose connection. If splitting appliances onto their own circuits doesn't fix this you would probably want an electrician to come in and check for other underlying causes which could represent a fire hazard.
Hope this helps.
Apr 01, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
