Question about Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error 09,036.44:23385
I tried to print something and received this error: 09,036.44:23385
Can anyone help?
    President:
  • 2,072 Answers
That message is telling you that one of your ink sticks is not advancing downward in the ink loader. One of the sticks is either somewhat crooked and jammed, maybe cracked or just somehow stuck.
If someone managed to get the ink sticks in from another phaser Xerox product, it will be shaped different and will not actuate the switch at the bottom of the ink loader.
You can take a screw, like a dry wall screw and insert it in to the ink stick to remove them if needed. I seriously doubt the loader itself has failed.
Posted on Aug 02, 2008
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
Note
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Oct 14, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Camshaft is broke in my xerox phaser 8560 mfp
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
Yhe usual problem with this model is the process motor, that brakes down and needs replacement. I'm afraid you can't replace it yourself as it takes alignment and timing adjustments
Aug 04, 2014 | Xerox Office Equipment & Supplies
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
8560 System Error 39,003,40:6082
Replace the scanner assembly(flat bed)
Mar 12, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Booklet Printing
It indicates a driver error.
Try going to xerox.com and loading a different driver.
at Xerox.com click support and drivers
at the search box enter phaser 8560 and change the driver you are using.
PS drivers sometimes have glitches. Reload a new driver and i suspec that will resolve the issue.
Dec 25, 2007 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
487 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
