Question about Zanussi Washing Machines
I have a zanussie jetsystem 1600 Err 40 keeps comingn up. I've just cleared out the filter behind the little flap in the bottom let hand corner, but I can't get the machine to do anythng and i've got clothes trapped inside.
    Brigadier General:
  • 6,277 Answers
Have you checked the operation of the drain motor itself? If not here is part of my guidance notes for filter and motor.
SWITCH OFF POWER
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 18, 2011
Zanussi jetsystem 1600
Get all of your towels. That little square on the bottom there. Open it with a flat head screw driver. There's going to be a trap there. Unscrew the lint trap by twisting the filter counter clock wise. Be warned, this releases the water. Check to make sure that trap isn't completely clogged with stuff. Put the trap back in tight and properly make sure the tub holds water before putting the square plate back on. ; ) . Voila
Apr 27, 2013 | Washing Machines
Washing machine keeps stopping
E20 not draining error. Since you checked filter at bottom right corner for blockages, then maybe the drain pump has gone faulty or something jammed in it. You can also check the drain hose for kinks or blockages. You can try blowing out any cloggs in the machine with an air compressor.
Please let me know if you need any further help, otherwise good luck on fixing your problem.
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I need to clear the filter on my zanussi zwf16070w washing machine but dont know how to and cannot find the manuel for it??
If it is a british made washer, then the filter is usually located at the bottom front right of washer behind a drop down flap or cover, unscrew filter anti-clockwise to remove and clean.
Oct 13, 2010 | Zanussi Washing Machines
Error code 40
call AAA washing machine doctor on 0863949848 or visit aaawashingmachinedoctor.com
Mar 02, 2010 | Washing Machines
Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2010 | Washing Machines
My zanussi timeline 1600 washing machine has problems draining. Is there a way to fix this easily?
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Please rate my solution.
Thankyou.
Jan 16, 2010 | Zanussi ZWF1650W Front Load Washer
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Sep 29, 2007 | Washing Machines
Washing Machines Logo
205 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
