Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
How do you get the rear-access door open to clear a paper jam? The model I have is a KODAK ESP5210
  • Kodak Master
  • 4,338 Answers
Remove and inspect the paper tray.
CAUTION: Do not place the printer on its top or right side when you remove the paper tray. Ink could possibly leak into the printer and cause damage.
  1. Turn off the printer.
  2. From the back of the printer, disconnect:
    • power cord
    • USB cable (if used)
  3. Turn the printer on its left side.
  4. Open the paper tray.
  5. From the bottom of the printer, do the following depending on your printer model:
  1. Check the paper tray for the following:
    • surface scratches
    • bends
    • ink contamination
    • broken parts
  2. If the paper tray is broken, contact Kodak to order a replacement, otherwise do the following:
  3. Install the parts that were removed in Step 5.
  4. Place the printer upright.
  5. Connect:
    • power cord
  6. Turn on the printer.
  7. Make a print to check the functionality of the paper tray.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Mar 18, 2011
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
HOW DO I CLEAR PAPER JAM ON KODAK ESP.5
It's probably a fragment or small piece. Look at paper path with a lot of light very carefully. You may need to dismantle to clear it.
Aug 08, 2014 | Kodak EasyShare Office Equipment &...
Where is the rear access door on a kodal 3250?
There is no door, just an opening to allow you to clear a paper jam or to vac out paper dust.
Nov 20, 2013 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Feb 11, 2011 | Office Equipment & Supplies
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
389 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
