Question about Kodak EASYSHARE 5100 All-In-One Printer
Scanner my scanner will not work. when i hit the scan button and then start it just beeps when i hit start. it will not scan.
  • Anonymous Aug 03, 2008
    i hit scan then start and it dosent scan.
    it just blinks -___-
  • Offenbacker Aug 09, 2008
    I have set the print up on XP & Vista. The Scanner has never worked
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
This MAY be due to the printer NOT being plugged directly into the power in the wall. some printers will NOT scan under power strip connections.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
This printer is the worse
Posted on Sep 02, 2008
All channels locked out
Press scan, then press a number button and it will scan that bank -pick a number from 0-9 and it should scan that. If you did truly lockout everything hit 'manual' then hold down the L/O Lockout button for 3 seconds and you'll hear a beep- that should unlock everything.
Mar 21, 2014 | Radio Shack Pro-97 Handheld Scanner
I think my scanner only scans in the 30s. I also see a P on the left side of the screen on some of the numbers
  • The "P" means you have the scanner scanning only priority channels.
  • To get rid of the "P" simply press the PRG button on the far right and bottom of the key pad and hold for 5 seconds. No the scanner should be off Priority.
  • Now pick any channel that is not Locked Out and hit the "L/O" button which is the button all the way on the bottom second to the left from the wight on the keypad. Hold this for five seconds until you hear two beeps and all your channels will be unlocked and you will have free scanning capabilities again.
  • Removing the "P" might be the fix right off the back depending on how many priority channels you have.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 30, 2011 | Uniden BC80XLT Handheld Scanner
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the...
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Oct 05, 2010 | Opticon OPN 2001 Mobile Data Collector...
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Cannot unlock Uniden BC60XLT-1 (30 ch VERSION)
if all the channels are 000.000 then it wont scann youll have to hit manual then enter a freq then hit the "e" button. once you hit manual youll be able to push the up and down arrows to select an channel you wish to imput a feq. Hope this helps.
David
Jun 29, 2009 | Uniden BC60XLT Handheld Scanner
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Kodak EASYSHARE 5100 All-In-One Printer Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
