Coils need replacement - Heating & Cooling
    Brigadier General:
  • 4,736 Answers
Sorry to hear that. What would you like to know? Keep in mind, we need a Manufacturer and Model Number of the unit to be able to help you.
Posted on Mar 18, 2011
2004 Chrysler Pacifica coil pack replacement instructions
It says you need to remove the upper intake manifold to get to the coils,here's the link to it,then I will send the other link to removing the coils too. Repair Guides Engine Mechanical Components Intake Manifold AutoZone com Here's the second link on removing your coils. Repair Guides Distributorless Ignition System Ignition Coil AutoZone com
May 14, 2017 | Chrysler Cars & Trucks
What is the A-coil that is compatible with furnace model KG7SC072D24B?
Looking at the model # it appears that you may have a 2 ton unit. Evaporator coils come in different sizes -
You should be able to get the correct size by providing the A/C repair company with the name of the manufacturer and the Model Number.
Generic coils, should you need one because yours is no longer being manufactured, do come in all different sizes.
I don't know if you want to replace the evaporator coil or have a service company do it. But if you do there are some things you need to know.
If the unit is an older unit the evaporator coil along with the box it sets in needs to be replaced because the drain pan is probably rusted out.
Additionally the box the new coil sits in is is going to be different in size then the original.
So a transition will need to be made from the furnace to the new A-coil box.
So with all that being said - if you have a credible A/C company replacing the coil you won't have any problems with them finding a replacement coil. They are in the business of doing this type of work and come across this situation all the time.
Oct 06, 2014 | Heating & Cooling
Spark plug wire install on ryobi ss26 edger
if the clip on the end broke off that can be replaced but if its on the coil end you need to replace the coil
Apr 07, 2012 | Garden
How do you change coil packs on a 2002 Mazada tribute v6
I believe the Mazda V6 is the same as my 2002 Escape and uses individual coil-over-plugs or COPs. Each spark plug has it's own coil.
I've had an engine light twice, and needed to replace coils. I finally replaced them all. They are available at Ford, car parts stores like AutoZone, or I bought my full set of 6 coils on Ebay.
Autozone coils, for example are about $70/coil.
One of the difficulties with replaceing the coils, is that the 3 coils on the "back" of the engine are covered by the intake manifold. The manifold needs to be removed to get to them. You'll need the manifold gasket set, which costs less than $15.
The coils themselves are easy to replace. Unplug the 2 wire connector, unscrew one bolt (using 8mm socket?), and pull the coil up and off the plug.
I recommend replacing all the coils, and also replace the plugs while you're in there. Use OEM plugs; probably Motorcraft. (If the original plugs lasted 100,000+ miles, why would you experiment with something else?)
Here's a picture of one coil:
Aug 29, 2011 | 2002 Mazda Tribute
I need to replace an ignition coil and plug on my 04 Ford Escape. Is this a difficult task? Can someone provide instructions?
If you have a V6 and it's like my 2002 V6, it will depend on with plug/coil you need to replace. The front 3 are very easy to replace. For the back 3, you'll need to remove the upper intake manifold (get a gasket set from the parts store).
Assuming it's a COP system (Coil Over Plug), each plug has it's own coil. Unplug the wires from the coil. Remove the one bolt with an 8mm? socket. Pull the coil off the plug. Using the correct socket, remove the plug.
If you have to remove the manifold for the back 3 plugs/coils, that will be more complicated. I would recomend going to:
http://escape-central.com
Add do a search for "intake manifold remove".
One of the first one's will have excellent instructions and photos.
Feb 08, 2010 | 2004 Ford Escape
Blown voice coils
Well the voice coil is a basic electromagnet. Electromagnet is a coil of wire, usually wrapped around a piece of magnetic metal, such as iron. there are many things need to keep in mind while replacing the voice coil like - wire size, length, type...... usually the speakers not works good after replacing the voice coils and replacing the speakers is the better option regarding money..... anyway you can please tell us the type or model of your speakers if you need more help or information........
Good Luck!!
Thanks
Jan 29, 2010 | PowerBase Car Audio & Video
I recently checked brought my car to the local
There are 6 coils that fire the spark plugs. You only need to replace the coils that are misfiring. Some autoparts stores will let you use a diagnostic meter for free. The code will tell you which cylinder is misfiring and the autoparts store can tell you the firing order so you can locate which cylinder & coil.
Unless your car is due for a tune up I would just replace the faulty coil and not the spark plugs. Dealer will always recommend replacing all the coils. Eventually another coil may fail but who knows when that will be. When you notice the symptom again just tackle it as you did this one.
Aug 03, 2009 | 2000 Nissan Maxima
#4 coil needs replacing
here is what i remember ... there was a class action law suit against VW about the high failure rate of the coils especially for the 4 cyl cars with turbo ... VW lost and agreed to install heat shields around the coils ... not sure what years are involved but you might check with a VW dealer to see if you come under that agreement .. as i recall VW charged a fortune for the replacement coils and labor.. a few years ago you could expect a second coil to go bad and even a third or all eventually .. VW would only change one coil at at time when in warranty .... the replacement coil did not appear to be an improved version .. .. it looks like VW is obligated to install the heat shields on models included in the suit ..
May 10, 2009 | 2003 Volkswagen Passat
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
