Question about Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ...
Ethernet 1-4 & WPS LEDS/LIGHTS NOT BLINKING - Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ...
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Jan 06, 2015 | Computers & Internet
Why is my WPS button blinking?
A blinking WPS on the router usually means it is actively waiting for a device to connect. For security reasons, it is best to set a time limit for how long WPS pairing can remain active in the router, or to turn WPS off completely and connect only with a standard WPA/WPA2 security key.
Once a device is connected via WPS, it is as secure as if it was connected with a standard security key. WPS is only there as a way to make connecting to routers easier with a shorter password that is supposed to only work for short time while WPS pairing is enabled. ALL OTHER TIMES, WPS SHOULD BE TURNED OFF!
Oct 08, 2014 | Computers & Internet
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can't get my BL-PA300KTA to connect. I have plugged it in and pressed the Setup buttons (within 3 seconds Mater and Terminal). The PC, LAN, and Master lights are ligting up as they should (I believe), with...
I use these and the previous model without any issues.
1. They must be plugged into the wall socket. It's okay to use an extension cord between the adapter and the wall, but never a surge suppressor or UPS
2. The master need to be connected to you router
3. To test your connection do the following
-Plug the master into the wall at the router location
-Plug the slave into the outlet where the computer will be
-Press and hold the setup button on the slave unit only for 3-5 seconds
The leds on the slave will flash for a second or two and then turn solid.
The number of solid lights you see tell you what your connection speed will be 0-no connection, 1-<10MB , 2=-10-30MB, 3->30MB.
I always unplug the ethernet cables from the adapter when testing, but I don't know if that is necessary.
I have never gotten less then 2 leds in my house, but it's new.
Sep 01, 2009 | Panasonic Network Camera HD-PLC Bridge...
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
All the Lights are flashing on my HL 5250DN
If printer is blinking all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on and try to print again. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Jun 23, 2009 | Brother HL 5250DN Laser Printer
Blinking panel lights
To Calibrate , start and warm engine to normal operating temp. with engine idling turn blower switch to high, turn mode switch to panel, open all outlets, move temp lever to full cold.
press and hold rear wash and rear wiper buttons simultaneously for 5 seconds (untill all leds illuminate.) all leds should light up for 5 seconds, rear wiper and intermittent rear wiper button leds will flash alternatly during calibration... after 60 seconds if only rear wiper button led is flashing, cal. is complete
Jun 18, 2009 | 1998 Plymouth Voyager
Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ... Logo
65 people viewed this question
Top Aztech Computers & Internet Experts
Ali Reza
Level 1 Expert
James Van Damme
James Van Damme
Are you an Aztech Computer and Internet Expert? Answer questions, earn points and help others
