Question about Maytag Washing Machines
Water going into tub without washer on - Maytag Washing Machines
  • 770 Answers
You have bad water inlet valve shut the water off at the wall to stop
Posted on Aug 02, 2008
5 Suggested Answers
  • 113 Answers
SOURCE: keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Posted on Apr 24, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag washer runs and runs water, no stop.
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 28, 2010
  • 44 Answers
SOURCE: my general electirc washer model
I had a similar problem ... mine was related to a hole in the pressure switch hose (code E22). Inside the washer, there is a pressure switch that senses how full the tub is. It does so using air pressure at the bottom of the tub -- air hose gets "pushed on" by the filling water and causes a pressure spike the switch. If you develop a leak in the air hose, the pressure switch never gets exhausted. There is a safety feature that engages if the water runs for more that 8 minutes without the pressure switch engaging. E22 is one of the codes related to this event. Easy way to see if this is an issue is to run a diagnostic test.
Check out this posting for how to do so: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you do find a pressure switch related code, here's how to fix it: http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Posted on Jul 28, 2011
  • 13 Answers
SOURCE: water does not go into washer
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an Efollowed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Posted on Dec 04, 2011
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
Top loading washing Kichenaid leaks water into tub; turn off cold water and stops leaking; how to fix
Hello Keith, If what your experiencing is after wash the tub is empty but you look a day later and their is water in the tub without using the washer,the water inlet valve on the back where the hoses connect to is not fully and seeping water slowly but steadily into tub and must be replaced. The part number for that valve is 285805 it could be purchased at your local appliance parts store or online at searspartsdirect.com repairclinic.com apdepot.com assuredparts.com appliancepartspros.com I hope will help you to fix your washer, Gene
Aug 09, 2011 | KitchenAid KAWS700L Top Load Washer
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
No water coming out
Clean out or replace the tube running from the water level switch in the backsplash to the washer tub. It tends to plug up with gunk right where it attaches to the outer tub. When it gets plugged, the washer can not tell if the tub is empty or full.
Aug 13, 2009 | General Electric WJRR4170GWW Top Load...
Keeps filling with water, but draining at the same time!
Apr 24, 2009 | Washing Machines
Water filling tub
You need a new cold inlet valve fitting.
Dec 08, 2008 | Kenmore 44042 Front Load Washer
Water leaks out from underneth
We have a WDSR2080D GE washer and had the same exact problem. We replaced the water pressure switch ($30) to see if that was the cause. A malfunction in this switch would cause the leaking from the bottom because there would be no way for the washer to "know" that the tub was filled to the appropriate level--causing the tub to overflow. Then we found out that the water pressure switch was not the cause and found that the water pump switch was the problem. A malfunction with this switch would cause water to continue to fill the tub without stopping--which would cause an overflow. Think of it as turning on a faucet without the ability to turn it off. Happily, we are now with a working and non-flooding washer at only a minimal expense. Note that the schematics for your washer are not in the manual. They are inside the control panel, which means you have to take the front of the washer off as well as the control panel in order to see what's really going on. My guess is that GE would rather consumers not try to fix their own appliances so they put instructions and helpful hints INSIDE the appliance.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
