Question about Ryobi 10 In Miter Saw With Laser
Bushing were burned. I replaced them pulled the trger and they burned again. what is the problem
The screen flickers and darkens while watching the TV. It is a 3 month old Bush DLED32165HD. Adjusting contrast/brightness/sharpness makes no difference. Turning off the TV and turning it on again, th
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 14, 2015 | Bush Televison & Video
Why does the sound keep going off on my Bush LED tv
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 06, 2014 | Bush Televison & Video
Rear upper and lower control arms life replaced at 70k,replaced at 85k, replaced at 100k,replaced at 115k now at124k needs to be replaced again what could be problem?
Have you had a four wheel alignment done recently? Do you replace all the links in their entirety, or just the bushes? If just the bushes, try an aftermarket set of poly bushes?
what happened just before 70k? Did you have a crash? Did you damage the axle/housing (bent rear axle)?
please tell us how you solved this problem as it could help someone else in the future..thanks.
Jun 16, 2014 | 1999 Nissan Pathfinder
I was drilling and it started smelling kinda like burnt plastic. now when i pull trigger, nothing happens at all. the drill is a bosch 1194vsr hammer drill
Sounds like you need bushings do not try again till you replace then as you may damage the armiture......
there should be two plastic slotted screw caps somewhere on the drill........remove those and a bushing will pop out replace those by ordering fron tool repair shop......should cost only a few dollars
Feb 14, 2011 | Garden
Tv has no power
Maybe the fuse is burn out causing not to on the power. try to replace the fuse if burn again . theres a power supply is shorted .you need a technician to fix your problem,.
Jun 28, 2010 | Bush 5693D 24" TV
How to install rod bushings on a harley , 98 softail 1340cc.
Replacing rod bushings is not a difficult job but you must have some special tools if you're going to do it with the crank assembly still in the cases.
Harley makes a special tool with which you remove and reinstall the bushings with. Basically, it's a couple of metal cups and a bolt. You ues the cups in one way and pulls the old bushing out. Use them the other way and pulls the new bushing back into the rod.
Once you have the new bushings in place, you must have a special **** with which to **** the new bushing to the correct inside diameter.
If you have the crank out of the cases and the crank is disassembled, you can have the rod bushings replaced the way most other such bushing are replaced in a machine shop. They have equpment to press the old bushings out and new ones back in and then hone the bushing to size. Simply take them your rods, the new bushings, and a new piston pin for sizing the bushing too.
I do not have the part numbers for the tools needed to do this job as I don't have a service manual in front of me. If you need the numbers of those tools, contact me directly at wd4ity@bellsouth.net Good Luck!
Jan 24, 2010 | 2000 Harley Davidson FLSTC Heritage...
Tie rod
No. Go to Napa, get the bushing repair kit. Turn the steering wheel all the way to the right. Remove the air inlet tube. Should be 2 7/8" bolts retaining the inner tie rod ends. Loosen both. Remove one at a time, replace bushing with kit. Use some synthetic brake grease on the bushings. I recommend Napa sylglide. Replace the bolt, but do not tighten all the way. Do the other the same way. Tightnen both bolts, reinstall the air inlet tube, get vehicle aligned.
Jul 22, 2009 | 2002 Dodge Intrepid
Polo pulling to the left
get the tracking done (not just the front wheels get the back done aswell)
Jan 29, 2009 | 1999 Volkswagen Golf
Removal and replacement of lower shock bushing while still on car?
Burned out the old bushing, cleaned up the shock mount and pressed in the new bushing using two 1 and 1/4 sockets and a bolt and nut tightning to press the new bushing in. Worked like a charm. Better than Jaguars solution of removing the shock. Oh yes, light grease on the bushing and shock mount. Paul
Jul 15, 2008 | Jaguar XJ8 Cars & Trucks
Break problem
burn light bulb light bulb number 3157 2 contact bulb power is on on 1 element and when you apply the brake it goes on the other element and the other element is burn thanks for using fitya pierre
Feb 10, 2008 | XO Vision GX1211 XOVision 12" Roof Mount...
Ryobi 10 In Miter Saw With Laser Logo
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
