Question about Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to be OK, but not as Cold as it should be. Cleaned (Vacumed off Rear Coils for Fan, which was completly covered in Dust. 2 days ago, I noticed that the Frezzer was running constantly so, I turned it down and the fan turned off. I then turned it back up to a higher setting to re-adjust over night. This is when I woke this morning to find everything Almost thawed completly.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Manual
There are several 'types' of electric air heaters. Some have solid-state control boards, others, bi-metalic strip, and open contacts. The most simple is a bi-metalic strip and an adjustment knob for the temperature. Turn knob to lowest setting, plug unit in, turn knob to full, then when room is comfortable, then adjust knob until you hear a click. now system will cycle on - off keeping the room at the temperature you set.
Apr 16, 2014 | Heating & Cooling
I opened the door on GE Profile side by side refrigerator this morning. Not only was the the refrigerator not blow cool air. It was actully blowing hot air, it was like opening the oven. The temperature on...
Check if it is still under warranty - I think that it is usually 2 years.
When in this condition, was the compressor still running ?
There was one issue that occurred occasionally on some models - the fridge door has a height adjustment so you can level the 2 doors up. Sometimes, it drops a bit too much, and on models with the fridge door light switch on the top (not the side), it meant that it wasn't turning off the light. Some have 2 lamps (commonly 40W or more each), so you effectively have 80Watts or more of heating running constantly. If your (exact) model has the door switch on the side, this is Unlikely to be the issue.
If the compressor was not running, I could say something like "it might have got stuck in a defrost cycle", but this DOESN'T really fit with the operation of these fridges (no defrost elements in the fridge side).
Does this help in any way ??
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Back lights are dim on speedometer, odometer
You probably checked this, but sometimes we forget.
The dial on the dashboard to the left of the instrument panel controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness. Also, to reduce glare at night, the fuel and temperature gauges dim when you turn on the parking lights or headlights. You then adjust their brightness when you adjust the instrument panel brightness.
Turn the dial up as far as it will go to return the fuel and temperature gauges to their daytime brightness.
I hope helps and it's that simple for you.
Nov 03, 2009 | 1996 Honda Prelude
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Oct 18, 2009 | Honeywell Electronic Programmable...
OVEN STAYS HOT
This is somethig you should have checked by technician.Till then turn the oven off then pull straight out on the knob removing it. use a plyers to check if it's actually turning off by turning it to the left. If it does turn to the left( off position) you may just need a new knob.
Oct 04, 2009 | Ovens
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Dec 12, 2005 | Emerson MW8775W Microwave Oven
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
