Question about Tech Solution TS-6000 Shredder
Hi, One of the plastic gears inside the gear
Hi, One of the plastic gears inside the gear box has worn teeth and one tooth missing. Is it possible for me to order replacement plastic gears. If so,how much would the cost be including shipping. Thank You Dennis
  • 76 Answers
Honestly Dennis - these bad boys are quite vicious and go up like jack-in-the box when you attempt to take them appart - I would recommend you bin it and buy a new one.
Posted on Mar 18, 2011
2003 toyota camry 4cyl.engine doesnt turn over but starter does.starter ck. and is ok , just makes starter whining noise
if starter motor runs (hear it??) but doesn't turn engine , then it needs to be replaced also at same time , the gear it contacts with on flywheel edge ,needs to be visually inspected (easy with starter removed) for any missing or bent teeth , as a engine this old is bound to have some worn or missing teeth, if gear is missing teeth or are very worn (teeth looks like a shark fin with hook to them) then engine and transmission will need to be separated to be replace the gear , most shops will just remove engine to allow for this , but this isn't always nessacary
Dec 14, 2016 | Toyota Cars & Trucks
Westwood t1600
It appears you need to post in another location. Most hard drives do not have gear boxes.
Jun 15, 2014 | Computers & Internet
Clicking noise coming from tansfer case at low speed on 2000 Olds Bravada
clicking noises in gear boxes/ transfer case generally is an indication of teeth damage on a gear . ( piece of the gear missing) The noise occurs when that broken bit comes into the mating gear and has to re-mesh correctly. Pull the drain plug and check the magnet for a bit of tooth
Jan 25, 2014 | Hummer H3 Cars & Trucks
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
Craftsman model 917377411 front propelled drive not engaging
On your model I beleive these wheels are driven with small gears inside the inside diameter of the wheels. If the shaft is turning, then you probably have a gear problem. Remove a wheel and inspect both the wheel, and the small gear. They are prone to wear.I'd suggest replacing all four parts if worn.
Jul 18, 2010 | Craftsman Garden
The speedo driven gear of my Toyota Corolla is
hi, you can replace it with that one but the speedo would be between 1 and 2mph out as they use different amounts of teeth depending on the size of your wheels, it wont do no harm just be carefull going past speed cameras
Jan 09, 2010 | 1998 Toyota Corolla
Grinding when starting, replaced starter one month ago engages well sometimes, but now will not engage flywheel could the flywheel teeth be worn or broken?
The flywheel is worn in that specific area. Engines tend to stop in the same one or two positions, and it is those teeth that get cachunked every time you turn the key. This is ok if the bendix does a good job of threading the gear into the flywheel teeth, but the problem is that now that the teeth are half worn away, the starter attempts to mount its gear to the teeth, but before the gear is fully seated, the contacts in the motor make, the motor starts to turn, and the not-yet-seated gear bounces off of the flywheel teeth. This is what causes the teeth-grinding sound (your teeth grinding in your mouth too!) when you turn the key. . There are two solutions: The first is to, of course, replace the ring gear. . The second is hard to explain, but a good starter rebuild center (if there is such an accessible animal around anymore) will know what I'm talking about: The starter gear must have the lagging edge of each tooth ground so that each tooth will look like a chisel. The "pushing" side of each tooth must be straight and come to the point (and not be beveled). The "non-pushing" lagging side of each starter tooth should have the bevel ground in on that side. This grinding is done easily by a small angle grinder or a Dremel Tool with a cutoff wheel. . This does one thing: It assures that the gear will "spin in" without bouncing. If ground correctly (it's not hard to do), you will get successful starts every time. This is a common fix for Toyota 4-cyl with this horrible all-too-common problem. Good luck.
Nov 25, 2009 | 1987 Chevrolet S-10 Pickup
Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Jul 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Tech Solution TS-6000 Shredder Logo
206 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
