Question about Tricity Bendix TM310W Electric Dryer
Tricity bendix dryer- type P542232. - after a couple of dries, a small leak. How can I fix it.
  • andy_watt Mar 18, 2011
    Hi Daniel, Thanks for getting back.
    It is a condensing Dryer only.
    Theres a small puddle on the floor, which seems to come from under the machine, but not every time it's used, maybe a 2-3 times before the leak.
    Thanks. Andy
  • 4,323 Answers
Hi
From where is it leaking, from the bottom of the unit or from the top, is it a washer or a dryer or a washer/dryer unit. Please elaborate and post back for further assistance.
Daniel
Posted on Mar 18, 2011
  • Daniel Scott
    Daniel Scott Mar 18, 2011
    The issue can be with the outlet side of the pump that is broken and so leaking, you can check it and if bad should be replaced
How do i fix a tricicty bendix dryer
You need to call a technician. If this unit is only 6 months old, it must be under some type of warranty.
May 04, 2015 | Tricity Bendix Washing Machines
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Jan 14, 2014 | Tricity Bendix TM310W Electric Dryer
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Brand new washer dryer leaking - Triciy WDR1241
Go back to dealer ,make sure it is plumed OK .close bye
Oct 08, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix TM310W Electric Dryer Logo
60 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
