Question about Deluo (851017001104) GPS Receiver
I need a driver for a laptop GPS (Deluo GPS Universal)
Gps problem with panasonic toughbook
I recently had GPS problems on a series of
Panasonic Toughbook CF30's which all had
built-in GPS. The GPS had to be enabled in
the BIOS and when I tried to install drivers for
Windows 7 then I ran into problems.
In a pinch Vista 32-bit drivers can be used for
Windows 7 32-bit. Eventually since I needed the
GPS drivers to work I re-installed Windows XP
service pack 3 and no more problems.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jun 24, 2014 | Panasonic Toughbook Computers & Internet
I have this drive for windows xp but no i have windows 7
Quick and dirty answer just install the program under windows 7 should run OK, if it doesn't then run it in winxp compatibility mode and should work from there.
Apr 25, 2010 | Deluo (851017001104) GPS Receiver
USB ports no longer work
you need to check your device manager and make sure the device manager is reading the USB ports, if not, you will need top get a USB driver or go to ADD NEW HARDWARE, and search through there until you find universal serial hub or bus then click ADD
May 05, 2009 | Gateway 6510GZ Notebook
Connecting furuno gp32 nto laptop
This is a problem in Windows where NMEA data is interpreted by the computer as serial mouse inputs. There are various fixes. If you type Windows mininsterpret NMEA serial mouse into Google you will find lots of info.
Dec 11, 2008 | Furuno GP32 GPS Receiver
Polstar GPS Device
throw it in the gutter go and get another
Jul 18, 2008 | Deluo RoadMentor GPS Receiver
I have microsoft streets and trips 2007 and I have media player 11
How can you get MS-Streets & Trips 2007 into full screen. It will only open in a 6 x 6 window and far too hard to read. When I first used S/T it was full screen but have not been able to get back there since. Have tried several time re-intalling and read everything I can find and still no go. Any information will be appreciated.
Thanks Larry
Nov 17, 2007 | Microsoft Deluo Universal GPS USB...
Cursor bouncing
I have had some similar issues, I find I must wait till my mapping program is fully open and running before I plug in my GPS unit, and the problem doesn't resurface.
Oct 25, 2007 | Microsoft Deluo Universal GPS USB...
Deluo (851017001104) GPS Receiver Logo
184 people viewed this question
Top Deluo GPS Experts
Will Halftowaite
Are you a Deluo GPS Expert? Answer questions, earn points and help others
